Advanced Member ghib Posted February 14, 2017 Advanced Member Report Share Posted February 14, 2017 http://3dcoat.com/forum/index.php?/topic/19525-3d-coat-47-beta-testing-thread/&do=findComment&comment=139854 This issue is still not resolved. I try not to despair but I'm failing sorry. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 2, 2017 Report Share Posted March 2, 2017 ghib I use this settings for that task. I found it resolved. Quote Link to comment Share on other sites More sharing options...
Advanced Member ghib Posted March 9, 2017 Author Advanced Member Report Share Posted March 9, 2017 Thanks again Carlosan, if you look just two posts down I replied to you. It seems still not resolved in the latest version. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 9, 2017 Report Share Posted March 9, 2017 That doesn't work with Imported NormalMaps, yes. It's how it works, its not a bug. If you have suggestions to change the way of how is working, I advise you to open a ticket for feature request at mantis. Ty. Quote Link to comment Share on other sites More sharing options...
New Member Tristan_bethe Posted December 6, 2018 New Member Report Share Posted December 6, 2018 Is there a solution for this problem currently? Just as the ghib I loaded a normal map from substance painter and want to use a mask on this but it does not work (or at least not as with diffuse textures. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 6, 2018 Report Share Posted December 6, 2018 Hi Ext Normal maps cant be edited, sorry. Quote Link to comment Share on other sites More sharing options...
New Member Tristan_bethe Posted December 6, 2018 New Member Report Share Posted December 6, 2018 That is too bad. Any other way around this? Or only to generate a normalmap inside 3d-coat? Quote Link to comment Share on other sites More sharing options...
New Member Tristan_bethe Posted December 6, 2018 New Member Report Share Posted December 6, 2018 Although I see I can just use a eraser to remove the normal map.. bit destructive but will do for my use now Quote Link to comment Share on other sites More sharing options...
