Kitbashing
Sebastián Benítez
Do you make your kitbash models inside 3d coat? If so, what is your workflow?
I copy the kitbash meshes (obj) to specific folders located in the 3D-Coat Program/Application folder (depending on your OS), under VoxStamps/Objects/nameyourfolderhere
Then use models or splines to add it to the scene
And transform or pose tool to follow the base sculpt mesh
Tool option > on pen is a great option to use too
I meant if you create your own models as part of your workflow and whether you do it inside 3d coat or in other 3d application.
Edit: more specifically, how suitable is 3d coat for making kitbash sets to reuse within 3d coat.
Edited by Sebastián Benítez
Addendum
- I meant if you create your own models as part of your workflow
sometimes yes
- and whether you do it inside 3d coat
yes
- or in other 3d application
yes
I noticed there appear to be two locations to add stuff like kitbash models on my computer :
Some are installed here
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps
And other here
C:\Program Files\3D-Coat-V4.7.24X\VoxStamps
Which is correct? Are both required?
I find installing stuff in the same folder as the application very messy and frustrating. Each time there is an upgrade to 3DC I have to re-install all the voxstamps, splines, materials, stencils, etc to the new Program Files folder.
Would it not be better just to have a standard folder in my documents that is independent of 3DCoat version?
ie: C:\Users\kenmo\Documents\3D-Coat\VoxStamps
To look Date modified help ?
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps  is dated Nov 13, 2016 and this is where the TinkerObjects are installed
C:\Users\kenmo\Documents\3D-CoatV47\VoxStamps\Objects\_TinkerObjects
C:\Program Files\3D-Coat-V4.7.24X\VpxStamps is dated Feb 17, 2017
So which path is the correct or default location? It appears to be OK to use both...
It is difficult for me to guess since I do not know the installation. I would delete or add files to a single folder to see if any changes are made. That's all I can think of.
  • 7 months later...
