Member BrandonK Posted March 9, 2017 Member Report Share Posted March 9, 2017 Hello, I am a complete newbie in 3D coat. Tried to solve this problem with searching but I could not find the answer. When I see others using pose tool, after selection they can "pose" the entire voxel. But no matter what I try I can only select the surface I am facing. (attached 1,2) When I try to stretch it I can only stretch the selected surface, obviously. (attached 3) Is there any way I can select the entire voxel while facing one direction? Oh and even worse, when I ctrl+z I get this dirty remaining and my 3D coat did not used to do that. (attached 4) I've already re-installed 3D coat and everything. Is this how this program supposed to be? Thank you very much for your time. Quote Link to comment Share on other sites More sharing options...
Member ThomasBrissot Posted March 9, 2017 Member Report Share Posted March 9, 2017 Hey BrandonK, Just uncheck the "ignore back faces" in stroke mode Quote Link to comment Share on other sites More sharing options...
