Member ThomasBrissot Posted March 9, 2017 Member Share Posted March 9, 2017 Hello, I have been playing with the cut off tool, which is super quick and efficient if you use custom shapes. I find that using custom shapes (via the "load shape" button in stroke mode) gives far better results that cutting of with a stencil of the same shap, the cut is sharper, less "aliased" and it's fun and quick to place it, rotate it etc.. But reloading the shape each time is not a great workflow. Maybe Instead of having to open the stroke mode, click on load shape, select the shape or spline in a folder and then resizing, and then finally cutting through the volume with our custom shape, it would be great to add the custom shape once and for all maybe via a thumbnail in the stroke mode window, or in a library on the side (like the one with stencils) ? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20825-cut-off-shape-interface-suggestion/ Share on other sites More sharing options...
Carlosan Posted March 9, 2017 Share Posted March 9, 2017 Hi ! This video covers the usage of Tool Presets and the Preset Panel in 3D Coat Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20825-cut-off-shape-interface-suggestion/#findComment-144342 Share on other sites More sharing options...
Member ThomasBrissot Posted March 9, 2017 Author Member Share Posted March 9, 2017 Thanks for the video ! I actually had created a preset (and saved the presets file) but it didn't save the shape I loaded for the cut-off tool, so clicking the "cut off with a shape" preset simply takes me to the cut off tool. (I have to load the shape again via load shape etc...) Any thought on that ? Maybe I'm doing something wrong? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20825-cut-off-shape-interface-suggestion/#findComment-144343 Share on other sites More sharing options...
Reputable Contributor digman Posted March 9, 2017 Reputable Contributor Share Posted March 9, 2017 (edited) 11 minutes ago, ThomasBrissot said: Thanks for the video ! I actually had created a preset (and saved the presets file) but it didn't save the shape I loaded for the cut-off tool, so clicking the "cut off with a shape" preset simply takes me to the cut off tool. (I have to load the shape again via load shape etc...) Any thought on that ? Maybe I'm doing something wrong? I do not think you can save a shape preset in the regular preset panel... Under the "what to store" there is no "saving Shape" Your suggestion would make a good feature request. We have thumbnails of models, strips, splines and brush alphas for choosing. Adding a Shape section would be good. Edited March 9, 2017 by digman Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20825-cut-off-shape-interface-suggestion/#findComment-144344 Share on other sites More sharing options...
