New Member davidirl Posted March 31, 2017 New Member Share Posted March 31, 2017 I am trying to use smart materials, but im getting like wierd, 10% of the smart material results, as if I had multiply turned on or something. But I dont, everything is default and I cant figure out what happened over night, things were fine yesterday! I have tried many different meshes etc, same results, restarted, same. here is a gif of what I am seeing, what setting is on or what is happening? I am at a full stop here and so confused! I have watched lots of tutorials, but have NO clue how to even describe with words what this problem even is: http://imgur.com/CTt0Fbi Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 1, 2017 Reputable Contributor Share Posted April 1, 2017 (edited) Always best to give the version of 3DC you are using. Your opacity for color is set to 23% Also your workflow is lacking in details. like what kind of model is it. Is it imported directly using Per Pixel mode into the paint room, a surface mode model and you are vertex painting or a baked model from the retopo room. All the above each go into a possible answer but for now the simplest to try is to set your opacity to 100% Edited April 1, 2017 by digman Quote Link to comment Share on other sites More sharing options...
Advanced Member Garagarape Posted April 1, 2017 Advanced Member Share Posted April 1, 2017 Hello there! I hope someone will help you. Your issue may be related to your graphic card (not sure though). I don't have the knowledge to give a hand, but it may be better if you add your machine specifications (OS, which graphic card, RAM, etc...) to your message. Your post is recent, so be patient. I bet administrators will have a look soon. Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted April 1, 2017 Contributor Share Posted April 1, 2017 (edited) Opacity is lower than 50% , its at value 23 , this may be your issue. Just read the other comments , its definitely opacity as David is pointing out as well. Graphics artifacts is from the gif Edited April 1, 2017 by Michaelgdrs Quote Link to comment Share on other sites More sharing options...
