I do not believe it is possible at this time...
There is somewhat of a workaround:
As you build your topology you can use the seam tool to separate the edge loop faces. Just do not unwrap.
The choice of colors is auto by 3DC and the loop faces colors can change at times if you delete some seams.
Once completed with the retopo, clear your seams.
I changed my seam selection color to white under the preferences menu.
Remember this is just a workaround. A feature reque
Posted by digman,
Recommended
Recommended by Carlosan
2 reactions
Go to this post
