Licenses questions
mkdm
Hi 3D-Coat team.
I currently own 3D-Coat pro license and maybe, in a few weeks, I would need to switch to a new computer while keeping the old one.
What happens if I will install 3D-Coat on the new computer ?
Is it possible to install it on more than one machine while using it only on one machine at a time ?
If this is not the case, what I have to do in order to use 3D-Coat on the new computer ?
Thanks and have a nice day.
- Marco (mkdm)
 Hi !
As long as you aren't running the program on both computers simultaneously, 3D-Coat has no issues with you installing it on up to three different machines. If you happen to have it running on both machines at the same time, 3D-Coat will warn you about it, and eventually restrict your usage.
Basically, make sure the program is closed on the other machine before opening it on your current one.
