Member Andreas Wolmer Posted May 26, 2017 Member Report Share Posted May 26, 2017 Hi! First off, I apologize if this is a really stupid question. Maybe I'm missing something really obvious, but I just can't seem to find a way to reset a Surface or Voxel tool to the default settings after having changed them either myself or by selecting a tool preset. Have googled and searched the forums, but no luck. Can anyone shed some light on this mystery? Thanks in advance / Andreas Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted May 27, 2017 Contributor Report Share Posted May 27, 2017 There is a 'Customize UI' selection in the Edit menu but how it works I don't know. Quote Link to comment Share on other sites More sharing options...
Member Andreas Wolmer Posted May 28, 2017 Author Member Report Share Posted May 28, 2017 Thanks, but that seems to be for controlling what tools etc appear in the UI. I'm looking for something that just resets tool settings such as radius, falloff, steady stroke etc to default. Cheers Andreas Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 29, 2017 Report Share Posted May 29, 2017 You may quickly reset any brush folder to default. - Close 3D-Coat. - open MyDocuments\3D-CoatV4xx\textures\patterns\ You may delete files there - all or separately. Each brush representted by 2 files .mclp and .xml Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 30, 2017 Reputable Contributor Report Share Posted May 30, 2017 I don't think there is tool reset option. I have long wised Andrew would add this. I don't often need it, but it can be a PITA when you do. Quote Link to comment Share on other sites More sharing options...
Member Andreas Wolmer Posted May 30, 2017 Author Member Report Share Posted May 30, 2017 12 hours ago, AbnRanger said: I don't think there is tool reset option. I have long wised Andrew would add this. I don't often need it, but it can be a PITA when you do. Yep, it would be sweet to be able to simply "right click -> reset tool". Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted May 30, 2017 Reputable Contributor Report Share Posted May 30, 2017 1 hour ago, Andreas Wolmer said: Yep, it would be sweet to be able to simply "right click -> reset tool". Send Andrew a request (support@3dcoat.com). Maybe he will add it, soon. It would be nice to have the Primitives in the Retopo Room have a reset option. Some of them have a Reset Axis/Scale, but not all of them. Quote Link to comment Share on other sites More sharing options...
Member Andreas Wolmer Posted May 30, 2017 Author Member Report Share Posted May 30, 2017 1 hour ago, AbnRanger said: Send Andrew a request (support@3dcoat.com). Maybe he will add it, soon. It would be nice to have the Primitives in the Retopo Room have a reset option. Some of them have a Reset Axis/Scale, but not all of them. Ok, will do! 1 Quote Link to comment Share on other sites More sharing options...
Member lambertj21 Posted December 1, 2020 Member Report Share Posted December 1, 2020 Did this ever get addressed? As I play more and more with presets, I have to keep deleting the 'my documents' folders to get back to a starting point. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 1, 2020 Report Share Posted December 1, 2020 Hi Send Andrew a request (andrewshpagin@gmail.com) reporting it. Thx Quote Link to comment Share on other sites More sharing options...
