Member sun_smasher Posted June 16, 2017 Member Report Share Posted June 16, 2017 I was working in 3D coat last night, got to a stopping point, saved and closed. Today when I loaded the file up, my bottom layer is completely grey, all of my painting is gone. The other layers seem to be fine, it's just the bottom most layer that was affected. What could be causing this? It happened before to me when I was using the trial version, closed it to put in the registry key, and then on opening all of my layers were grey or messed up somehow. I thought at the time it was probably just a bug from the file going from a trial to a full version, but now I'm not so sure. On an unrelated note, but still an issue that is very annoying is that I don't see the nodes that tell me where my points are for the gradient. When I pick 1 and pick 2, the points are put in the world (because they have coordinates) but there's no visual representation of where they are. I only knew there was meant to be nodes because I watched the tutorial, but nothing in the tutorial mentioned (that I heard) a way to toggle these nodes on or off, so I'm not sure where they are. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted June 16, 2017 Contributor Report Share Posted June 16, 2017 If the bottom layer you mention is "Layer 0", it should be grey and you must never paint on it or delete it as it contains baked info. Can't help with problem 2, sorry. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 16, 2017 Report Share Posted June 16, 2017 The second issue was solved in the latest version Quote Link to comment Share on other sites More sharing options...
Member sun_smasher Posted June 16, 2017 Author Member Report Share Posted June 16, 2017 3 hours ago, Carlosan said: The second issue was solved in the latest version Ah... I don't know if I want to install a beta just yet... that being said it seems like the gradient tool is simply broken for me completely now, so I'm searching for why that might be. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 16, 2017 Report Share Posted June 16, 2017 Is a software bug solved in latest version. Quote Link to comment Share on other sites More sharing options...
