Crash at startup/launch - Macbook Pro 2017 (3D-Coat 4.7.23)
  • New Member
I have a new MacBook Pro 2017 (meets system specifications and running Sierra OS), but 3D Coat version 4.7.23 keeps crashing at startup. I installed version 4.5.xxx but these either crashed, froze, or gave me red-screens.
What do I do? I already purchased a license.
Thanks for any help!
Andrew
copy/pasted my error crash log here on Sierra OS, 3D Coat version 4.7.23 --
Loading Xml file "Xmls/Settings.xml"...
Can't load file "Xmls/Settings.xml"
 OpenGL | Version: 4.1 ATI-1.51.8
 OpenGL | Vendor: ATI Technologies Inc.
 OpenGL | Renderer: AMD Radeon R9 M295X OpenGL Engine
 OpenGL | Supported features:
 OpenGL | Multitexture (fragment shader units: 16)
 OpenGL | Anisotropic filtering (level: 16)
 OpenGL | Texture Compression DXT
 OpenGL | Vertex Array Object
 OpenGL | Vertex Buffer Object
 OpenGL | Vertex Attributes (count: 16)
 OpenGL | Vertex Uniform Vectors (count: 1024)
 OpenGL | OpenGL Shading Language
 OpenGL | Frame Buffer Object (max size: 16384 X 16384)
 OpenGL | MRT (targets: 8)
 OpenGL | Extensions (46) : GL_ARB_blend_func_extended GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader5 GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_occlusion_query2 GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_subroutine GL_ARB_shading_language_include GL_ARB_tessellation_shader GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_vertex_attrib_64bit GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_EXT_texture_mirror_clamp GL_EXT_texture_sRGB_decode GL_APPLE_client_storage GL_APPLE_container_object_shareable GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_texture_range GL_ATI_texture_mirror_once GL_NV_texture_barrier
Registering vertex formats...
3Dconnexion framework found
cMeshIO::AddCodec(): Added "Obj" mesh codec.
cMeshIO::AddCodec(): Added "Lwo" mesh codec.
cMeshIO::AddCodec(): Added "Fbx" mesh codec.
cMeshIO::AddCodec(): Added "Stl" mesh codec.
cMeshIO::AddCodec(): Added "Ply" mesh codec.
cMeshIO::AddCodec(): Added "dae" mesh codec.
cMeshIO::AddCodec(): Added "wrl" mesh codec.
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sphere.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Ring.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cube.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Sector.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cone.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets//Cylinder.obj".
cMeshIO::LoadMesh(): Can't open file "/private/var/folders/6g/ndg4srq16qg4j6j6vy118pph0000gp/T/AppTranslocation/9A9A5B2B-721A-40D2-B2C2-362D17CFCEA1/d/ToolsPresets/icosa240.obj".
Added "TIF" image codec.
Added "TIFF" image codec.
Added "EXR" image codec.
Added "HDR" image codec.
 - Loading font "Calibri 11"...
Can't load file "Fonts/Calibri 11.cFont"
 - Loading font "Calibri 16"...
Can't load file "Fonts/Calibri 16.cFont"
 - Loading font "Calibri B24"...
Can't load file "Fonts/Calibri B24.cFont"
 - Loading font "Tahoma 8"...
Can't load file "Fonts/Tahoma 8.cFont"
 - Loading font "Tahoma B8"...
Can't load file "Fonts/Tahoma B8.cFont"
Can't load image file "Textures/WindowsStandard/ToolBar.bmp"
Version : 3D-COAT 4.7.23(GL64)
Can't load file "Shaders/hud2t.glsl"
Can't load file "Shaders/Low/hud2t.glsl"
Can't load file "Shaders/VeryLow/hud2t.glsl"
Can't load file "Shaders/hud_smooth.glsl"
Can't load file "Shaders/Low/hud_smooth.glsl"
Can't load file "Shaders/VeryLow/hud_smooth.glsl"
Can't load file "Shaders/hud.glsl"
Can't load file "Shaders/Low/hud.glsl"
Can't load file "Shaders/VeryLow/hud.glsl"
Can't load file "Shaders/LinesPointsUI.glsl"
Can't load file "Shaders/Low/LinesPointsUI.glsl"
Can't load file "Shaders/VeryLow/LinesPointsUI.glsl"
Can't load file "Shaders/Colored.glsl"
Can't load file "Shaders/Low/Colored.glsl"
Can't load file "Shaders/VeryLow/Colored.glsl"
Can't load file "Shaders/RenderSystem.glsl"
Can't load file "Shaders/Low/RenderSystem.glsl"
Can't load file "Shaders/VeryLow/RenderSystem.glsl"
Can't load file "Shaders/text2.glsl"
Can't load file "Shaders/Low/text2.glsl"
Can't load file "Shaders/VeryLow/text2.glsl"
Can't load file "Shaders/obj_sel.glsl"
Can't load file "Shaders/Low/obj_sel.glsl"
Can't load file "Shaders/VeryLow/obj_sel.glsl"
Can't load file "Shaders/obj_render_color.glsl"
Can't load file "Shaders/Low/obj_render_color.glsl"
Can't load file "Shaders/VeryLow/obj_render_color.glsl"
Can't load file "Shaders/obj_render_normals.glsl"
Can't load file "Shaders/Low/obj_render_normals.glsl"
Can't load file "Shaders/VeryLow/obj_render_normals.glsl"
Can't load file "Shaders/obj_render_mrt.glsl"
Can't load file "Shaders/Low/obj_render_mrt.glsl"
Can't load file "Shaders/VeryLow/obj_render_mrt.glsl"
Can't load file "Shaders/tex_preview.glsl"
Can't load file "Shaders/Low/tex_preview.glsl"
Can't load file "Shaders/VeryLow/tex_preview.glsl"
Can't load file "Shaders/tex_preview_nrm.glsl"
Can't load file "Shaders/Low/tex_preview_nrm.glsl"
Can't load file "Shaders/VeryLow/tex_preview_nrm.glsl"
Can't load file "Shaders/tex_preview_alpha.glsl"
Can't load file "Shaders/Low/tex_preview_alpha.glsl"
Can't load file "Shaders/VeryLow/tex_preview_alpha.glsl"
Can't load file "Shaders/tex_preview_all.glsl"
Can't load file "Shaders/Low/tex_preview_all.glsl"
Can't load file "Shaders/VeryLow/tex_preview_all.glsl"
Can't load file "Shaders/obj_preview_pen2.glsl"
Can't load file "Shaders/Low/obj_preview_pen2.glsl"
Can't load file "Shaders/VeryLow/obj_preview_pen2.glsl"
Can't load file "Shaders/inrect.glsl"
Can't load file "Shaders/Low/inrect.glsl"
Can't load file "Shaders/VeryLow/inrect.glsl"
Can't load file "Shaders/preview_rect.glsl"
Can't load file "Shaders/Low/preview_rect.glsl"
Can't load file "Shaders/VeryLow/preview_rect.glsl"
Can't load file "Shaders/draw_pic_over_curve.glsl"
Can't load file "Shaders/Low/draw_pic_over_curve.glsl"
Can't load file "Shaders/VeryLow/draw_pic_over_curve.glsl"
Can't load file "Shaders/preview_fill.glsl"
Can't load file "Shaders/Low/preview_fill.glsl"
Can't load file "Shaders/VeryLow/preview_fill.glsl"
Can't load file "Shaders/uv.glsl"
Can't load file "Shaders/Low/uv.glsl"
Can't load file "Shaders/VeryLow/uv.glsl"
Can't load file "Shaders/wires.glsl"
Can't load file "Shaders/Low/wires.glsl"
Can't load file "Shaders/VeryLow/wires.glsl"
Can't load file "Shaders/sphere.glsl"
Can't load file "Shaders/Low/sphere.glsl"
Can't load file "Shaders/VeryLow/sphere.glsl"
Can't load file "Shaders/obj_preview_pen.glsl"
Can't load file "Shaders/Low/obj_preview_pen.glsl"
Can't load file "Shaders/VeryLow/obj_preview_pen.glsl"
Can't load file "Shaders/CurrentMcubes/mcubes.glsl"
Can't load file "Shaders/Low/CurrentMcubes/mcubes.glsl"
Can't load file "Shaders/VeryLow/CurrentMcubes/mcubes.glsl"
Can't load file "Shaders/mpreview.glsl"
Can't load file "Shaders/Low/mpreview.glsl"
Can't load file "Shaders/VeryLow/mpreview.glsl"
Can't load file "Shaders/mpreview1.glsl"
Can't load file "Shaders/Low/mpreview1.glsl"
Can't load file "Shaders/VeryLow/mpreview1.glsl"
Can't load file "Shaders/Font.glsl"
Can't load file "Shaders/Low/Font.glsl"
Can't load file "Shaders/VeryLow/Font.glsl"
Can't load file "Shaders/mcubes_rt.glsl"
Can't load file "Shaders/Low/mcubes_rt.glsl"
Can't load file "Shaders/VeryLow/mcubes_rt.glsl"
Can't load file "Shaders/mcubes_nrm.glsl"
Can't load file "Shaders/Low/mcubes_nrm.glsl"
Can't load file "Shaders/VeryLow/mcubes_nrm.glsl"
AppLink search path registered: /Users/Andrew1/AppLinks/3D-Coat/Exchange/
AppLink search path registered: /Users/Andrew1/3D-CoatV4/Exchange/
AppLink search path registered: /Users/Andrew1/3D-CoatV3/Exchange/
AppLink search path registered: /Users/Andrew1/3D-CoatV47/Exchange/
Can't load image file "Levels/Uv/Uv_d"
Crash occured. Trying to save object...
  • New Member
From the 3D-CoatV47/log.txt
Was uploaded again because a bug.
The version 4.7.32 is last one -uploaded 2 days ago-
osxicon.pngmacOS [4.7.32]:
http://www.3d-coat.com/~sergyi/3D-CoatV4-7-32.dmg
Ensure to check "System Preferences > Security & Privacy > click the "lock" > select "App Store and identified developers" (when only "App Store" is selected error message is displayed "3D-Coat" can't be opened because it was not downloaded from the App Store)
On "Retina" displays uncheck "3D-Coat > Geometry > Incremental Render"
Hi Carlosan:
I tried your link and the new download version (macOS [4.7.32]). 3D Coat still crashes at launch.
I posted the log.txt above. Here is the mac crash log (you can see my system specs).
Please help?
Thank you,
Andrew
Process:               3D-Coat [1402]
Path:                  /private/var/folders/*/3D-Coat.app/Contents/MacOS/3D-Coat
Identifier:            com.Pilgway.-D-Coat
Version:               4.7.32 (1)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           3D-Coat [1402]
User ID:               502
Date/Time:             2017-06-28 11:14:46.828 -0400
OS Version:            Mac OS X 10.12.5 (16F2073)
Report Version:        12
Anonymous UUID:        79F2351D-8B4F-08D3-DF19-5F18EE2628D3
Sleep/Wake UUID:       7C140CED-A1A2-4F40-ABB4-4D7A58368055
Time Awake Since Boot: 19000 seconds
Time Since Wake:       450 seconds
System Integrity Protection: enabled
Notes:                 Translocated Process
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000000000004a
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [0]
VM Regions Near 0x4a:
    __TEXT                 000000010b6e6000-000000010d5b1000 [ 30.8M] r-x/rwx SM=COW  /var/folders/*/3D-Coat.app/Contents/MacOS/3D-Coat
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.Pilgway.-D-Coat               0x000000010c03a80d VoxelSculptTool::ProcessVoxTree() + 243
1   com.Pilgway.-D-Coat               0x000000010c10ab9b BasicTool::DrawMesh() + 39
2   com.Pilgway.-D-Coat               0x000000010bcb708d MainRender() + 126
3   com.Pilgway.-D-Coat               0x000000010bcb7b59 MainCycle() + 130
4   com.Pilgway.-D-Coat               0x000000010b80bef4 comms::cMain_OnRender(comms::cRect const&) + 500
5   com.Pilgway.-D-Coat               0x000000010c1e9d8b cMacMain_OneIterationOfMessageLoop() + 2296
6   com.Pilgway.-D-Coat               0x000000010c1e926c main + 4060
7   com.Pilgway.-D-Coat               0x000000010b6eb744 start + 52
Thread 1:
0   libsystem_kernel.dylib            0x00007fffe50b844e __workq_kernreturn + 10
1   libsystem_pthread.dylib           0x00007fffe51a2621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib           0x00007fffe51a207d start_wqthread + 13
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0   libsystem_kernel.dylib            0x00007fffe50b7f46 __semwait_signal + 10
1   libsystem_c.dylib                 0x00007fffe503eb72 nanosleep + 199
2   libsystem_c.dylib                 0x00007fffe503ea66 usleep + 54
3   com.Pilgway.-D-Coat               0x000000010c35ac86 comms::SavingThread(void*) + 33
4   libsystem_pthread.dylib           0x00007fffe51a293b _pthread_body + 180
5   libsystem_pthread.dylib           0x00007fffe51a2887 _pthread_start + 286
6   libsystem_pthread.dylib           0x00007fffe51a208d thread_start + 13
Thread 6:
Thread 7:
Thread 8:
1   libsystem_pthread.dylib           0x00007fffe51a248e _pthread_wqthread + 1023
Thread 9:
0   libsystem_kernel.dylib            0x00007fffe50b034a mach_msg_trap + 10
1   libsystem_kernel.dylib            0x00007fffe50af797 mach_msg + 55
2   com.apple.CoreFoundation          0x00007fffcf810434 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation          0x00007fffcf80f8c1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation          0x00007fffcf80f114 CFRunLoopRunSpecific + 420
5   com.apple.HIToolbox               0x00007fffced70ebc RunCurrentEventLoopInMode + 240
6   com.Pilgway.-D-Coat               0x000000010c1e9f43 cMacMain_TdxThreadProc(void*) + 67
7   com.apple.CoreServices.CarbonCore    0x00007fffd071cf34 PrivateMPEntryPoint + 39
8   libsystem_pthread.dylib           0x00007fffe51a293b _pthread_body + 180
9   libsystem_pthread.dylib           0x00007fffe51a2887 _pthread_start + 286
10  libsystem_pthread.dylib           0x00007fffe51a208d thread_start + 13
Thread 10:
5   com.apple.CoreFoundation          0x00007fffcf84eb91 CFRunLoopRun + 97
6   com.3dconnexion.driver.client     0x000000010e6ee4ed -[ConnexionClientAPI clientThreadEntry] + 323
7   com.apple.Foundation              0x00007fffd1232b3d __NSThread__start__ + 1243
Thread 11:
0   libsystem_kernel.dylib            0x00007fffe50b9246 read + 10
1   com.apple.Foundation              0x00007fffd12164c4 _NSReadFromFileDescriptorWithProgress + 267
2   com.apple.Foundation              0x00007fffd12c479c -[NSConcreteFileHandle readDataOfLength:] + 498
3   com.Pilgway.-D-Coat               0x000000010c1e22a2 cMacMain_GetRootDiskUUID(comms::cStr*) + 215
4   com.Pilgway.-D-Coat               0x000000010b9cbc1a comms::cIO::GetDiskSerialNumber() + 304
5   com.Pilgway.-D-Coat               0x000000010bfc702c GetUHI() + 67
6   com.Pilgway.-D-Coat               0x000000010b75ef32 HttpThread(void*) + 683
7   libsystem_pthread.dylib           0x00007fffe51a293b _pthread_body + 180
8   libsystem_pthread.dylib           0x00007fffe51a2887 _pthread_start + 286
9   libsystem_pthread.dylib           0x00007fffe51a208d thread_start + 13
Thread 12:
3   com.Pilgway.-D-Coat               0x000000010c2c82b0 CheckFileThread(void*) + 124
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x000000010db11f60  rcx: 0x000000010daad900  rdx: 0x0000000000000030
  rdi: 0x000060800002d340  rsi: 0x000000010db12fc0  rbp: 0x00007fff54519740  rsp: 0x00007fff545195f0
   r8: 0x00646f6874656d5f   r9: 0x0000000000000000  r10: 0x0000000000000000  r11: 0x0000607ef2de2619
  r12: 0x0000000000000000  r13: 0x000000001ca4220f  r14: 0x0000000000000000  r15: 0x0000000000000000
  rip: 0x000000010c03a80d  rfl: 0x0000000000010246  cr2: 0x000000000000004a
Logical CPU:     2
Error Code:      0x00000004
Trap Number:     14
Binary Images:
       0x10b6e6000 -        0x10d5b0fef +com.Pilgway.-D-Coat (4.7.32 - 1) <0671DF70-DD1A-3A55-9605-4E946BD0E7F5> /var/folders/*/3D-Coat.app/Contents/MacOS/3D-Coat
       0x10e6ec000 -        0x10e6eefff +com.3dconnexion.driver.client (10.4.1 - 10.4.1) <60FB5A56-62BF-3FAF-9B59-65B7761DFAED> /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
       0x10e6fc000 -        0x10e72aff7 +libtbb.dylib (0) <99F780E9-29FC-C2F8-4E55-1CE6B6EECFEF> /var/folders/*/3D-Coat.app/Contents/MacOS/libtbb.dylib
       0x10e744000 -        0x10e756ff7 +libtbbmalloc.dylib (0) <1AB33A35-CFF9-36CE-CF73-3D8DBFB1E4E4> /var/folders/*/3D-Coat.app/Contents/MacOS/libtbbmalloc.dylib
       0x10e834000 -        0x10e9dafff  GLEngine (14.0.16) <1999FBF9-0B82-34B1-8876-87B4F82101BB> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x10ea1d000 -        0x10eae3ffb  com.apple.AMDRadeonX4000GLDriver (1.51.8 - 1.5.1) <C0CE54D7-6BEC-309D-9BC3-86BD21BFB942> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
       0x10eaff000 -        0x10eb29fff  GLRendererFloat (14.0.16) <8D11C08E-8249-38DB-9856-BFC01EEDE0CB> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x10efd0000 -        0x10f00ddc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
       0x10f05b000 -        0x10faf8ff7 +libfbxsdk.dylib (0) <3569FB9D-7B4F-3C91-9080-BE7D5122107F> /var/folders/*/3D-Coat.app/Contents/MacOS/libfbxsdk.dylib
       0x114e63000 -        0x1158b7ff7  com.apple.driver.AppleIntelKBLGraphicsGLDriver (10.25.13 - 10.2.5) <0D76431B-5382-326C-9EA5-05F6F6E400F9> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
       0x115be6000 -        0x116124ff3  ATIRadeonX4000SCLib.dylib (1.51.8.1) <0D655219-E342-3585-9144-229A2A8EFFCC> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
       0x1168e5000 -        0x116973fff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (10.25.13 - 10.2.5) <1422EA89-9F2D-3692-917B-AE0337910199> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
       0x11a42f000 -        0x11a43cfff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <A9F8C2E9-3C20-3E0B-A7F4-1F3A97AA0511> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
    0x7fffca780000 -     0x7fffca8b3ffb  com.apple.AMDMTLBronzeDriver (1.51.8 - 1.5.1) <C5621BA6-4B85-365B-AB46-51AE4F4860B1> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
    0x7fffcbfb1000 -     0x7fffcbfb5ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <752FDB92-EF67-3D04-BF40-A352BF1075CF> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fffcc2e5000 -     0x7fffcc2e5fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <56BC0026-C7C6-30F7-B279-12EEFCEC65D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffcc2e6000 -     0x7fffcc2fdffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffcc2fe000 -     0x7fffcc817feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffcc818000 -     0x7fffcc989ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffcc98a000 -     0x7fffcc99effb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffcc99f000 -     0x7fffccd95fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffccd96000 -     0x7fffccdacfff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffccdad000 -     0x7fffccdb3fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffccdb4000 -     0x7fffccdc8ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffccdc9000 -     0x7fffccf50fe7  libvDSP.dylib (600.60.1) <3EA6920C-9B9A-3B82-915F-FA3310F12833> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffccf51000 -     0x7fffcd003fff  libvMisc.dylib (600.60.1) <42C325BD-5DEC-390A-9955-5C21A6DD5B70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffcd004000 -     0x7fffcd004fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A729669F-0FC2-3359-BFB5-4FF110AC591E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffcd2c3000 -     0x7fffce09cff3  com.apple.AppKit (6.9 - 1504.83.101) <EC7BD195-F9E1-3E43-820A-5FDD0B2B0B67> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffce0ae000 -     0x7fffce0aefff  com.apple.ApplicationServices (48 - 48) <4C71CBA8-47E4-38BF-BE3B-F20DF8667D5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffce0af000 -     0x7fffce11dff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffce1b7000 -     0x7fffce2e6ff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffce2e7000 -     0x7fffce331fff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffce38e000 -     0x7fffce3c1fff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffce42e000 -     0x7fffce4d8ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffce4d9000 -     0x7fffce52afff  com.apple.HIServices (1.22 - 592.1) <7353E76E-9A3A-3693-87AF-41953585E024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffce52b000 -     0x7fffce53aff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffce53b000 -     0x7fffce588fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffce589000 -     0x7fffce5c4fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffce5c5000 -     0x7fffce5d0fff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffce5d1000 -     0x7fffce7ddfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <91D2BA22-B168-3A9A-9008-6FFC5A8FDC1E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffce7de000 -     0x7fffce7defff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <8C0153FD-FEFF-309C-AACD-BF9657A31F8E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffce947000 -     0x7fffced21fff  com.apple.CFNetwork (811.5.4 - 811.5.4) <4DBF8932-6286-3B23-87D9-63615B9958D9> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffced3b000 -     0x7fffced3bfff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fffced3c000 -     0x7fffced3ffff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fffced40000 -     0x7fffcf049fff  com.apple.HIToolbox (2.1.1 - 857.8) <CAB143FE-AEAF-3EDE-AD7B-C04E1B7C5615> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffcf04a000 -     0x7fffcf04dff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fffcf04e000 -     0x7fffcf053fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fffcf054000 -     0x7fffcf0ebff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffcf0ec000 -     0x7fffcf106fff  com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fffcf107000 -     0x7fffcf108ff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fffcf109000 -     0x7fffcf10bff7  com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fffcf10c000 -     0x7fffcf112ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffcf33d000 -     0x7fffcf3cafff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffcf3cb000 -     0x7fffcf3defff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffcf3df000 -     0x7fffcf6dafff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffcf6db000 -     0x7fffcf787ff7  com.apple.CoreDisplay (1.0 - 1) <AAD5DF0B-0D22-305E-86FF-BB1431130363> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffcf788000 -     0x7fffcfc21ff7  com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffcfc22000 -     0x7fffd02a4fff  com.apple.CoreGraphics (2.0 - 1070.22) <DA056FA2-D0B4-36D9-94DC-498B07B6D420> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffd02a5000 -     0x7fffd04e8ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffd064d000 -     0x7fffd064dfff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffd064e000 -     0x7fffd069ffff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffd06a0000 -     0x7fffd097bff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffd097c000 -     0x7fffd09affff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffd09b0000 -     0x7fffd09b8ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffd09b9000 -     0x7fffd0b25ff7  com.apple.LaunchServices (775.19 - 775.19) <94D15A2A-852C-3B4B-A701-43043C8F1527> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffd0b26000 -     0x7fffd0bd6ffb  com.apple.Metadata (10.7.0 - 1075.40) <DA911E1B-3977-386D-930D-96BD5085CB8E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffd0bd7000 -     0x7fffd0c36fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <B4851A17-9173-3270-AA18-64878F715D62> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffd0c37000 -     0x7fffd0ca7fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffd0ca8000 -     0x7fffd0cedff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffd0d76000 -     0x7fffd0ec3ffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffd0ec4000 -     0x7fffd0ef9ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffd0efa000 -     0x7fffd0f6bffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <6BF64C70-A204-3F98-8A03-0E0BE8D17551> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffd1069000 -     0x7fffd106efff  com.apple.DiskArbitration (2.7 - 2.7) <8AC72143-D3C4-3AA6-84DF-734E3AFAC49B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffd1200000 -     0x7fffd15a6ff3  com.apple.Foundation (6.9 - 1349.81) <730B7944-BB43-35D5-A546-9F6CCED4B9F3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffd15d2000 -     0x7fffd1603ff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffd16c3000 -     0x7fffd1766fff  com.apple.Bluetooth (5.0.4 - 5.0.4f18) <28505742-3EF6-3922-B543-4AD3568EECE2> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffd1767000 -     0x7fffd17fdff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <FACFAA58-BA94-3003-B3CA-5143D71B130A> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffd17fe000 -     0x7fffd1804ffb  com.apple.IOSurface (159.7 - 159.7) <40550017-EF96-3C52-B400-806AFEE4B134> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffd1857000 -     0x7fffd19b7fef  com.apple.ImageIO.framework (3.3.0 - 1599.10.2) <87AA4D39-0AFC-3A34-98EF-02710E2BF3CA> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffd19b8000 -     0x7fffd19bcfff  libGIF.dylib (1599.10.2) <6ED05614-1301-3452-943B-118F00F20C8D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffd19bd000 -     0x7fffd1aadff7  libJP2.dylib (1599.10.2) <72C00423-55F0-3CAD-B198-EF00950791E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffd1aae000 -     0x7fffd1ad1ffb  libJPEG.dylib (1599.10.2) <78945614-990F-3705-A91C-46F717F7C635> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffd1ad2000 -     0x7fffd1af9ff7  libPng.dylib (1599.10.2) <B800C14F-6E41-36B6-8DC1-1AE97A83A964> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffd1afa000 -     0x7fffd1afcff3  libRadiance.dylib (1599.10.2) <037D95B4-82A7-3A59-B3EB-0FF0977CF7A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffd1afd000 -     0x7fffd1b4bfff  libTIFF.dylib (1599.10.2) <CA2C7BF9-FDDB-36CF-B063-B075B29F8878> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffd28b2000 -     0x7fffd28cbff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffd30aa000 -     0x7fffd3105fff  com.apple.Metal (87.18 - 87.18) <5D59448B-8A0C-31CE-B325-2CA042BC8284> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffd39ee000 -     0x7fffd39f6fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffd3bcd000 -     0x7fffd3bd5ff7  libcldcpuengine.dylib (2.8.5) <2AE1242C-026B-33A3-94EA-2D2525EF1E5B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffd3bd6000 -     0x7fffd3c24ff3  com.apple.opencl (2.8.6 - 2.8.6) <C5AB1BE0-492F-3B4D-9A6B-7D4E9B5064E1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffd3c25000 -     0x7fffd3c3effb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffd3c3f000 -     0x7fffd3c4aff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffd3c4b000 -     0x7fffd3c4dfff  libCVMSPluginSupport.dylib (14.0.16) <A20EC348-37C9-33B6-9A81-06006F3214A1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffd3c4e000 -     0x7fffd3c51ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffd3c52000 -     0x7fffd3c56fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffd3c57000 -     0x7fffd3c60ff7  libGFXShared.dylib (14.0.16) <63542E68-EB1A-3ECF-AAFB-E7B8AB313C70> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffd3c61000 -     0x7fffd3c6cfff  libGL.dylib (14.0.16) <84BEED97-0A93-356D-A922-97EA311EA446> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffd3c6d000 -     0x7fffd3ca9ff7  libGLImage.dylib (14.0.16) <3518A85C-6905-3511-A6C9-2F82C519D28F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffd3caa000 -     0x7fffd3e20ff3  libGLProgrammability.dylib (14.0.16) <0EDA89D8-7C28-3D53-BDBA-7CB25232C329> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffd3e21000 -     0x7fffd3e62ff7  libGLU.dylib (14.0.16) <9860DCF7-56E0-3A8F-A377-52635C9D8B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffd47ca000 -     0x7fffd47d8fff  com.apple.opengl (14.0.16 - 14.0.16) <27E7D76E-A26B-39F8-8CF2-AB57920776A3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffd532a000 -     0x7fffd552afff  com.apple.QuartzCore (1.11 - 453.39.3) <423DDB40-F044-3BA3-A4B8-6F4BC563CD08> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffd5a91000 -     0x7fffd5d93ff7  com.apple.security (7.0 - 57740.60.18) <9BDEEF20-339F-3F48-8DA1-5B0BBD2683DB> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffd5d94000 -     0x7fffd5e09fff  com.apple.securityfoundation (6.0 - 55132.50.7) <4433C0CC-FE90-3DD3-BAC1-CC31D515B510> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffd5e34000 -     0x7fffd5e37ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <9F285B19-B53B-3502-85A2-72C26DB40EA7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffd61be000 -     0x7fffd622dff7  com.apple.SystemConfiguration (1.14 - 1.14) <2412CDE0-C317-31EA-8F53-7A58BBFCC720> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffd8aac000 -     0x7fffd8aceffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <935AF0B0-1BC3-34BA-B816-BAD1DD793B08> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffd8acf000 -     0x7fffd8adefeb  com.apple.AppleFSCompression (88.50.3 - 1.0) <FCEC0C8B-CE04-313C-A34E-1A1BDEAC9D12> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffd8bd2000 -     0x7fffd8c5d97f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffd9090000 -     0x7fffd910eff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffd9d99000 -     0x7fffd9dc0ff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffda6e5000 -     0x7fffda6eeffb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffdae36000 -     0x7fffdae46fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffdb181000 -     0x7fffdb1b1ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffdb442000 -     0x7fffdb4d1ff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffdb4d2000 -     0x7fffdb611fe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffdb612000 -     0x7fffdb6e2ff3  com.apple.CoreUtils (5.1 - 510.31) <5FB49B78-E1F2-3DC3-8062-0633C46EBAB2> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffdb732000 -     0x7fffdb797ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <3BA83987-DCA3-3124-AB7C-E968AB5FF815> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffdb798000 -     0x7fffdb7a6ff7  com.apple.CrashReporterSupport (10.12 - 827) <14037A71-ECFE-394A-8D6E-2CECE98F02EE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffdb818000 -     0x7fffdb822ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fffdb823000 -     0x7fffdb827ff3  com.apple.DSExternalDisplay (3.1 - 380) <A195C0CE-8E4E-384B-9556-8270E306FE1D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fffdb85d000 -     0x7fffdb8d2ffb  com.apple.datadetectorscore (7.0 - 539.1) <9C312AAC-8AEE-3C72-BDE5-7FBF62452525> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffdb90e000 -     0x7fffdb94dfff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffdb94e000 -     0x7fffdba5ffff  com.apple.desktopservices (1.11.5 - 1.11.5) <AC930E9D-01A6-39D4-9038-4CE2E26B297B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffdbd47000 -     0x7fffdc178ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffdd4cf000 -     0x7fffdd4cffff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffdd4dc000 -     0x7fffdd4e7ff3  libGPUSupportMercury.dylib (14.0.16) <7E99C736-2F48-313E-BEF6-6F8BABFADD9F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffdd7a0000 -     0x7fffdd7bcfff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffddecd000 -     0x7fffddf43ff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffde553000 -     0x7fffde55dfff  com.apple.IOAccelMemoryInfo (1.0 - 1) <299393BE-294E-360B-AA4B-15766A8AEB49> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
    0x7fffde55e000 -     0x7fffde565ffb  com.apple.IOAccelerator (311.13 - 311.13) <40C04C41-A76A-3687-8D64-F76E8C46AA81> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffde567000 -     0x7fffde57bff7  com.apple.IOPresentment (1.0 - 29.10) <40F1A7CD-B0F0-30DD-B933-DE4FD05AC169> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffde57c000 -     0x7fffde59efff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffde685000 -     0x7fffde83cfff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffdf15d000 -     0x7fffdf1d6ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffdf350000 -     0x7fffdf378ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <512ADEC6-D694-3D73-A48A-6BE79CD39539> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffdf42a000 -     0x7fffdf435fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffdfd0d000 -     0x7fffdfd4eff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <6A21AB41-3AAA-32F3-9D46-2555A143A8B9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffe0436000 -     0x7fffe0450fff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffe0469000 -     0x7fffe048cff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffe11e5000 -     0x7fffe1272fff  com.apple.Sharing (696.2.67 - 696.2.67) <9A379BEA-22EC-30A2-A7B1-256A720DE392> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffe1293000 -     0x7fffe14f9feb  com.apple.SkyLight (1.600.0 - 170.3) <4C1C9E56-DCEC-3515-991C-4979ECC12B0E> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffe16d8000 -     0x7fffe16e4ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffe1dd0000 -     0x7fffe1e44fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffe2283000 -     0x7fffe2289ff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffe2315000 -     0x7fffe23dbff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffe244f000 -     0x7fffe2450fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffe2451000 -     0x7fffe25e1ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffe3692000 -     0x7fffe3694ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffe36e9000 -     0x7fffe3704ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffe3705000 -     0x7fffe3710fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffe37a2000 -     0x7fffe37a3ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffe37a4000 -     0x7fffe39b7fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffe39db000 -     0x7fffe39dbfff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffe39dc000 -     0x7fffe39e0ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffe39e1000 -     0x7fffe39e2ffb  libSystem.B.dylib (1238.60.2) <FC9E9F13-3B18-305C-BE0A-97C7843652B0> /usr/lib/libSystem.B.dylib
    0x7fffe3a4e000 -     0x7fffe3a79ff3  libarchive.2.dylib (41.50.2) <B4F507BC-B24E-3BE7-B658-94D798E2CD81> /usr/lib/libarchive.2.dylib
    0x7fffe3a7a000 -     0x7fffe3af6fc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
    0x7fffe3afa000 -     0x7fffe3afaff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffe3afb000 -     0x7fffe3b0bff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffe3b0c000 -     0x7fffe3b1aff7  libbz2.1.0.dylib (38) <2B11AB25-8B43-37D3-8485-3D9D22348B22> /usr/lib/libbz2.1.0.dylib
    0x7fffe3b1b000 -     0x7fffe3b71ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffe3b72000 -     0x7fffe3b9cfff  libc++abi.dylib (307.3) <30199352-88BF-30BD-8CFF-2A4FBE247523> /usr/lib/libc++abi.dylib
    0x7fffe3b9d000 -     0x7fffe3badffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffe3bae000 -     0x7fffe3bc4fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
    0x7fffe3bc5000 -     0x7fffe3bc5ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffe3bc6000 -     0x7fffe3bc7ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffe3c81000 -     0x7fffe3d66ff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffe3f04000 -     0x7fffe3f57ff7  libcups.2.dylib (450) <C1BF9A4F-699D-30D2-9974-5E6619BFC81C> /usr/lib/libcups.2.dylib
    0x7fffe3fd2000 -     0x7fffe3fd2fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffe3fe2000 -     0x7fffe3fe7ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
    0x7fffe3fe8000 -     0x7fffe40daff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffe40db000 -     0x7fffe4300ffb  libicucore.A.dylib (57165.0.1) <422D8E4B-AABA-31DA-8F38-CDA9ECEAAFFB> /usr/lib/libicucore.A.dylib
    0x7fffe4306000 -     0x7fffe4307fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffe4308000 -     0x7fffe4321ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffe4322000 -     0x7fffe4338ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffe4339000 -     0x7fffe45e1ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffe4614000 -     0x7fffe468eff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffe468f000 -     0x7fffe4a61047  libobjc.A.dylib (709) <DC77AA6E-A4E4-326D-8D7F-82D63AA88F99> /usr/lib/libobjc.A.dylib
    0x7fffe4a64000 -     0x7fffe4a68fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffe4a69000 -     0x7fffe4a9afff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
    0x7fffe4ab7000 -     0x7fffe4ad3ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffe4b23000 -     0x7fffe4c70ff7  libsqlite3.dylib (254.7) <07CD6DE3-394D-3C6A-A4B4-4CAB1054A041> /usr/lib/libsqlite3.dylib
    0x7fffe4ccc000 -     0x7fffe4d1cfff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
    0x7fffe4d65000 -     0x7fffe4d72fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffe4d73000 -     0x7fffe4e62ffb  libxml2.2.dylib (30.16) <D2A6861B-D9FA-3BFC-B664-830C3FCE6065> /usr/lib/libxml2.2.dylib
    0x7fffe4e63000 -     0x7fffe4e8cfff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
    0x7fffe4e8d000 -     0x7fffe4e9eff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffe4ead000 -     0x7fffe4eb1ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffe4eb2000 -     0x7fffe4ebcfff  libcommonCrypto.dylib (60092.50.5) <02FE47FC-D00A-3990-9DBD-B2A9AA39CE0A> /usr/lib/system/libcommonCrypto.dylib
    0x7fffe4ebd000 -     0x7fffe4ec4fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffe4ec5000 -     0x7fffe4ecdfff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffe4ece000 -     0x7fffe4f51fdf  libcorecrypto.dylib (442.50.19) <42194A7F-53C3-3EC2-97BF-C18A8EF8F349> /usr/lib/system/libcorecrypto.dylib
    0x7fffe4f52000 -     0x7fffe4f83fff  libdispatch.dylib (703.50.37) <3FE5CFDE-16CD-3A4E-89BC-6B331ED71B26> /usr/lib/system/libdispatch.dylib
    0x7fffe4f84000 -     0x7fffe4f89ffb  libdyld.dylib (433.5) <EC3D88D2-3D40-3274-8E26-362C2D7352C8> /usr/lib/system/libdyld.dylib
    0x7fffe4f8a000 -     0x7fffe4f8affb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffe4f8b000 -     0x7fffe4f97ffb  libkxld.dylib (3789.60.24) <2FCC0970-D947-345B-B6C2-472D503A1DB3> /usr/lib/system/libkxld.dylib
    0x7fffe4f98000 -     0x7fffe4f98fff  liblaunch.dylib (972.60.2) <D3306CFF-58AA-3C90-B06C-B70E80E60C5B> /usr/lib/system/liblaunch.dylib
    0x7fffe4f99000 -     0x7fffe4f9eff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffe4f9f000 -     0x7fffe4fa1ff3  libquarantine.dylib (85.50.1) <C8C5B31D-D6B6-3CC8-AB5E-9DD4305451EF> /usr/lib/system/libquarantine.dylib
    0x7fffe4fa2000 -     0x7fffe4fa3ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffe4fa4000 -     0x7fffe4fbcff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffe4fbd000 -     0x7fffe4fbdff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffe4fbe000 -     0x7fffe504bfef  libsystem_c.dylib (1158.50.2) <DE159DA6-2D73-308B-999C-03A651297F6E> /usr/lib/system/libsystem_c.dylib
    0x7fffe504c000 -     0x7fffe504fffb  libsystem_configuration.dylib (888.60.2) <D2E06289-4FE5-3282-B50C-60A8392AD9C0> /usr/lib/system/libsystem_configuration.dylib
    0x7fffe5050000 -     0x7fffe5053fff  libsystem_coreservices.dylib (41.4) <CC4802AE-CD6A-3A24-92EA-C7A647FB3FB2> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffe5054000 -     0x7fffe506cfff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffe506d000 -     0x7fffe5073fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffe5074000 -     0x7fffe509dff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffe509e000 -     0x7fffe50c0ff7  libsystem_kernel.dylib (3789.60.24) <6E9E485F-91F6-36B7-A125-AE91DC978BCC> /usr/lib/system/libsystem_kernel.dylib
    0x7fffe50c1000 -     0x7fffe5108fe7  libsystem_m.dylib (3121.6) <163BF3A4-47AF-3ED9-929B-96CC69453B1E> /usr/lib/system/libsystem_m.dylib
    0x7fffe5109000 -     0x7fffe5127ff7  libsystem_malloc.dylib (116.50.8) <47F57687-28DF-3C7C-BD1E-E7E72FCCEFC9> /usr/lib/system/libsystem_malloc.dylib
    0x7fffe5128000 -     0x7fffe5181ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffe5182000 -     0x7fffe518bff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffe518c000 -     0x7fffe5195ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffe5196000 -     0x7fffe519efe7  libsystem_platform.dylib (126.50.8) <C55E9541-D89B-3A0B-B2D5-F3739989B224> /usr/lib/system/libsystem_platform.dylib
    0x7fffe519f000 -     0x7fffe51a9ff7  libsystem_pthread.dylib (218.60.3) <A16288DE-AF70-3076-9641-045AC3DBEDB3> /usr/lib/system/libsystem_pthread.dylib
    0x7fffe51aa000 -     0x7fffe51adff7  libsystem_sandbox.dylib (592.60.1) <12B0E190-EA4E-3ED2-84C6-95BBAF0C6BFA> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffe51ae000 -     0x7fffe51afff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
    0x7fffe51b0000 -     0x7fffe51b7ffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffe51b8000 -     0x7fffe51cbff7  libsystem_trace.dylib (518.60.2) <1A1ED423-E3A7-3B65-A275-4EEC32BDC5CA> /usr/lib/system/libsystem_trace.dylib
    0x7fffe51cc000 -     0x7fffe51d1ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
    0x7fffe51d2000 -     0x7fffe51fbff7  libxpc.dylib (972.60.2) <1C9AF716-69DF-359F-85E9-7DFDE362F9A2> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 11503
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=319.7M resident=0K(0%) swapped_out_or_unallocated=319.7M(100%)
Writable regions: Total=320.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=320.9M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               128K        2
Activity Tracing                   256K        2
CG backing stores                 53.6M        4
CG image                            52K        6
CoreAnimation                       76K        5
CoreUI image data                  936K        8
CoreUI image file                  184K        4
Foundation                           4K        2
Kernel Alloc Once                    8K        2
MALLOC                           177.9M       34
MALLOC guard page                   48K       11
MALLOC_LARGE (reserved)           53.8M        3         reserved VM address space (unallocated)
STACK GUARD                       56.0M       14
Stack                             14.1M       14
VM_ALLOCATE                         80K       14
__DATA                            28.4M      229
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       131.6M       15
__TEXT                           188.1M      224
__UNICODE                          556K        2
mapped file                       45.2M       13
shared memory                     16.4M       14
TOTAL                            770.4M      603
TOTAL, minus reserved VM space   716.6M      603
I got it to work by typing in the terminal " $ sudo /Applications/3D-CoatV4-7/3D-Coat.app/Contents/MacOS/3D-Coat "
I don't want to use the terminal to open 3D coat every time I need it :(
But, I have no idea how to open the program by clicking the app icon?  How do I make it so I can just click the app icon to open 3D coat?
Thanks,
Andrew
You could send your reports plus stating your problem to support.linux at 3dcoat.com with a link to your thread also.
Sergii is both the Linux and Mac programmer
Edited by digman
corrections
32 minutes ago, AndrewT913 said:
email sent. hopefully, there's a fix,
Have you added the 3DCoat.exe file to your Anti-Virus and/or Firewall EXCEPTIONS list? I'm on Windows, and once had issues opening 3D Coat. Very similar behavior. I even complained to Andrew about it and he was stumped. My AV had never bothered 3D Coat before, so it seemed there was no reason to check it, now. I tried anyway, and sure enough, that was the :(4!#&*#+! problem all along!
Someone else had a similar problem since, and I mentioned this, and sure enough that was the root of the problem. Their AV was suddenly flagging it and preventing it from opening.
Yeah, every driver/software app has been updated.
I'm running a Mac OSx system on a Macbook Pro (latest version 2017 15"). No anti-virus software on this computer other than the native OS security features which are already permitting me to use any application/program.
Thank you guys for your input. I'm still for another reply from developer-side :)
Okay, so it maybe due to the fact that I permissions is broken.
Mac Sierra OSx doesn't have a way to repair permissions manually. However, it still doesn't make sense when I try to do an uninstall and reinstall.
Pilgway, is there a file buried somewhere that doesn't get removed when you do an uninstall of the application?
I am not sure for the Mac where the 3DC extra folder resides but In Windows 7 it is under Users \ -------- \ My Documents is the 3DC folder. This folder has to be manually removed.  Note: The dashes are just place holders for my user name. This folder remains so all your custom settings, alphas, shaders, smart materials etc are in any updated versions you install after uninstalling.
Also a bunch of xml files are located in the extra 3DC folder, very seldom they can become corrupted exp. the options. xml file. That one easy to fix as you just delete it and 3DC creates a new one.
In your case I might still just remove the entire folder. The choice is yours.
I am not even sure if Mac has a separate 3Dc folder other than the install folder, a mac user would have to pop in here but you would I think know anyway.
You will lose all your settings and have to resister your 3DC again after removing the said folder once you install again.
Worth a try.
Edited by digman
"3D-Coat" crashes because macOS isolates "3D-Coat" executable from its data - typical problem under macOS Sierra. To solve it please do the following:
1. Remove folder "/Applications/3D-CoatV4-7".
2. Make sure that you have checked "System Preferences > Security & Privacy > Allow apps downloaded from: App Store and identified developers" before downloading disk image with "3D-Coat" on your Mac.
3. Download "3D-Coat 4.7.32" for macOS from here and drag & drop it onto "Applications" alias as usually:
http://3dcoat.com/forum/index.php?/topic/19525-3d-coat-47-beta-testing-thread/
In case these 3 steps will not solve the problem then please do these additional steps:
4. In Terminal go into "Downloads" folder:
$ cd ~/Downloads
5. Check extended attributes of downloaded disk image with "3D-Coat 4.7.32".
$ ls -l@ 3D-CoatV4-7-32.dmg
Among them should be "com.apple.quarantine".
6. Delete quarantine attribute:
$ xattr -d com.apple.quarantine 3D-CoatV4-7-32.dmg
7. Check that attribute "com.apple.quarantine" has gone:
8. Remove previous folder "/Applications/3D-CoatV4-7". Open in "Finder" this disk image with "3D-Coat 4.7.32" on which you have removed "com.apple.quarantine" attribute and as usual drag & drop it into "Applications" icon.
