Member hello Posted July 11, 2017 Member Report Share Posted July 11, 2017 Hello, I have an object with UV islands, I want to colorize each island separately, I bought this script: https://cgtools.com/uv-colorizer but it doesn't run, just crashing any version of C4D, so I need something similar. Can you please help? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted July 11, 2017 Reputable Contributor Report Share Posted July 11, 2017 (edited) Is the color ID map for 3DC or another application like SP or SD etc... There is no auto color ID maker in 3DC. I do not know of a script off hand though there might be one or if is possible to script one for 3DC. You can though use the texture editor window to fill each uv island with a separate base color and then export that has a PSD file for external use using Textures menu--- All layers color. This will save the color map with no bleed on the uv islands. It has been so long since I done this you will have to test yourself. Test a simple object first to save time to see what works. If you need a single layer image file, you can save the psd file as a png file using the many image editors out there or photoshop. Maybe someone else will jump in and post here a better or more detailed workflow. Here is a video though not in English. It appears he made the color ID map using Photoshop then imported that into 3DC using "All layers color" Maybe it will give you some ideas. https://www.youtube.com/watch?v=QYj69RtmPWA Remember I am just doing the best to help though it might not meet your specific needs. The example color ID map image converted to a png file. The second image is one that is exported in the normal fashion which would include the uv island bleed which is not what you want for a color ID map. Edited July 11, 2017 by digman Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 11, 2017 Report Share Posted July 11, 2017 Hi ! This request is open 0001089: RGB Automap Islands Bake from your highpoly model (Color ID map) feel free to add a +1 Quote Link to comment Share on other sites More sharing options...
Member hello Posted July 12, 2017 Author Member Report Share Posted July 12, 2017 My forum login did not work, so I'm adding +100 here can't believe this feature requested 2 years ago and still nothing. 1 Quote Link to comment Share on other sites More sharing options...
