Member halafradrimx Posted July 17, 2017 Member Report Share Posted July 17, 2017 So, when I use 3D coat sometimes the topology keeps using the command "invert mirror" sometimes when I do something. Is there a way to fix this? Why does it happens? Any turn around the issue? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 17, 2017 Report Share Posted July 17, 2017 Its virtual mirror command = off ? Quote Link to comment Share on other sites More sharing options...
Member halafradrimx Posted July 17, 2017 Author Member Report Share Posted July 17, 2017 (edited) Yes. Should I let it turned on or off? To be honest, I just want to use 3D Coat for Retopology, nothing else. Edited July 17, 2017 by halafradrimx Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted July 17, 2017 Contributor Report Share Posted July 17, 2017 Whether to use it or not depends on your preference. If you prefer symmetry on and virtual mirror mode selected, you will do all your work on one side and will eventually need to 'app;y' the mirrored half. With this mode deselected and Symmetry 'On', you can make edits on both sides where with virtual on you would only work one side. Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted July 17, 2017 Contributor Report Share Posted July 17, 2017 What Tony said. I personally never use Virtual Mirror Mode because I don't like to be restricted to one side of symmetry plane only. Freedom all the way. Quote Link to comment Share on other sites More sharing options...
