Advanced Member Kargall Posted July 25, 2017 Advanced Member Share Posted July 25, 2017 Hello,1 - I tried to import a character from Daz-Studio (* .dea) but 3DC does not correctly import textures. I am obliged to go through Blender then zapplink for it to work.Can you tell me why this problem.2 - Can you tell me what use the "Update" button (in blender)? Nothing happens .3-- The function "return of the object" of 3dc does not work. It's obscure it seems that nothing happens in blender thank you very much Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 25, 2017 Share Posted July 25, 2017 Hi ! Is Teleblender addon useful for you ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Kargall Posted July 25, 2017 Author Advanced Member Share Posted July 25, 2017 Hi ! Thanks Carlosan. I'll see with that. You are always there when you need help. Regarding the addon 3dc Applink in blender, could you tell me what use the "update" button? . And how to use the "return object" function in 3dc? Thank you Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 29, 2017 Share Posted July 29, 2017 1. Import the daz model Turning on Import Tiles as UVset. 2.If you have applink working, use send to get the Blender model imported into 3DC -> When you finish with your painting, use this command to send it back to Blender saving model and textures in the folder that 3dcoat uses to export Then on Blender use GetBack to import model and painted textures into Blender. Note: Use G3 figures or G8 figures without eyelashes. G8 has its eyelashes as a separate piece of geometry and when you export that out the eyelashes actually gets merged with the face and that causes issues with painting. But with G3 there is not separate piece of geometry over here for separate eyelashes. * If you like to use G8 figures before exporting the model remember to delete eyelashes pressing RMB over the model layer and select Delete G8 eyelashes. - To export the model without textures be ready that Collapse UV tiles and and Write surfaces are not enabled. - To export the model with textures be ready that Collapse UV tiles is not enabled and Write surfaces is enabled. - At export, Export UVsets as tiles must be turned ON. Related: Quote Link to comment Share on other sites More sharing options...
