Advanced Member Findus Posted July 28, 2017 Advanced Member Share Posted July 28, 2017 How can I assign a hotkey to the floating foreground color picker / palette (Not the pipette v)? The "end" key doesn't seem to work in this case. I could reset the shortcuts, since I think it's usually on "b", but then I'd lose my other shortcuts. Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted July 29, 2017 Author Advanced Member Share Posted July 29, 2017 I ended up fixing it manually in the saved hotkey file. Since I had to reset my hotkeys in order to get the code, here it is for anyone having the same problem: <OneHotKey> <ID>PICKER</ID> <Code>C</Code> <Ctrl>false</Ctrl> <Alt>false</Alt> <Shift>false</Shift> <AllowStack>false</AllowStack> <UserDefined>0</UserDefined> </OneHotKey> Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 30, 2017 Share Posted July 30, 2017 Thank you ! Quote Link to comment Share on other sites More sharing options...
