Member Adions Posted September 2, 2017 Member Report Share Posted September 2, 2017 I have some huge problems with the default Document folder (C:\Users\XXX\Documents\3D-CoatV47). I added some Alpha Textures and the folder is about to explode. The Texture Folder alone is about 50GB! 3d Coat is converting the textures in his own format, as I recognised. But a Alpha texture is about 130 MB. Are you serious? The original PSD file is about 8 MB. Is there a way to store brush alphas on a different drive to have a better time managing the Texture Folder. Thx. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 2, 2017 Report Share Posted September 2, 2017 On both Linux and Windows you can easily create a symbolic link to refer to another location, I hope this little trick will help you See more here: http://www.howtogeek.com/howto/16226/complete-guide-to-symbolic-links-symlinks-on-windows-or-linux/ Quote Link to comment Share on other sites More sharing options...
Member Speike-Styles Posted September 3, 2017 Member Report Share Posted September 3, 2017 (edited) 4 hours ago, Adions said: I have some huge problems with the default Document folder (C:\Users\XXX\Documents\3D-CoatV47). I added some Alpha Textures and the folder is about to explode. The Texture Folder alone is about 50GB! 3d Coat is converting the textures in his own format, as I recognised. But a Alpha texture is about 130 MB. Are you serious? The original PSD file is about 8 MB. Is there a way to store brush alphas on a different drive to have a better time managing the Texture Folder. Thx. Hi, I recently talked with Andrew about this and he gave me the best solution ever! You only need to change the path. Doing this is a life-saver! Here the full Details: http://3dcoat.com/files/floating.pdf Separating changed data from installed files to share data between users Other possibility (optional, just for convenience) is to separate 3D-Coat’s installed files and files that was changed during the work so that you may place 3D-Coat installation files to protected or read-only location. Install 3D-Coat to any location (even protected or user- dependent). After that you should create file coat_data_path.txt in the same folder as executables or define environment variable COAT_FILES_PATH that will point to the location of changed data files. Path should be ended with slash “/” . License file should be placed in the same folder as all data files. In this case all changed files wil be written to new location but if installation location is read only you will not be able to delete any folders or files (like initial brushes, materials, strips, models) of initial installation inside 3D-Coat’s shell. If you will not create file coat_data_path.txt and will not define variable COAT_FILES_PATH then 3D-Coat will use 3D-CoatV4 folder in User’s folder under any OS. Edited September 3, 2017 by Speike-Styles 1 Quote Link to comment Share on other sites More sharing options...
Member Adions Posted September 3, 2017 Author Member Report Share Posted September 3, 2017 Hi Speike-Styles. Thx for the tip. How does the content of the coat_data_path.txt look like? ____________________________________ COAT_FILES_PATH E:\Dokumente\3dCoat\3D-CoatV47/ ____________________________________ Something like this? Quote Link to comment Share on other sites More sharing options...
Member Speike-Styles Posted September 16, 2017 Member Report Share Posted September 16, 2017 (edited) On 9/3/2017 at 10:03 PM, Adions said: Hi Speike-Styles. Thx for the tip. How does the content of the coat_data_path.txt look like? ____________________________________ COAT_FILES_PATH E:\Dokumente\3dCoat\3D-CoatV47/ ____________________________________ Something like this? Sry for the late reply. Just came back from a trip It is pretty simple. Just install 3DC "lets say \C\Program\3DCoat\ and before starting 3DC create the "coat_data_path.txt" and put it inside the main folder where 3DC is installed. Then open the "txt" and write in the path/folder where you want to have all the 3DC Packs presets etc to be like this exp:" D:\3DCoat\" This will create a auto exchange path from User/doc to the new folder. Clean and simple Hope you understand how it works now BTW anyone else reading this. This is the cleanest way to keep your presets if you want to Wipe your PC. BCuz 3DC will install normally all it's data Presets under the user/Documents folder and by doing it the way written above you are saving your presets on a different drive. Thus keeping it 4evr Safe Edited September 16, 2017 by Speike-Styles 3 Quote Link to comment Share on other sites More sharing options...
Member Adions Posted October 19, 2017 Author Member Report Share Posted October 19, 2017 Thx! It Works Perfect! The only thing is that on my other non ssd hard drive it takes ages to load my alphas. I think 3d Coat is made to work with a ssd hard drive. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 26, 2019 Report Share Posted February 26, 2019 On 9/27/2017 at 8:39 AM, SERGYI said: You should define environment variable "COAT_FILES_PATH" with full path to your custom documents folder. Please read more here:http://pilgway.com/~sergyi/Docs/CustomDocumentsFolder.pdf Quote Link to comment Share on other sites More sharing options...
