Member Nidhogg Posted September 6, 2017 Member Share Posted September 6, 2017 Hi there, Trying to import 3b files into each other. However when I do so, the instanced meshes and original from which they are instanced disappear from the model from the file I'm already working in. Any ideas? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 6, 2017 Share Posted September 6, 2017 Have you exported the scene or object before ? Quote Link to comment Share on other sites More sharing options...
Member Nidhogg Posted September 6, 2017 Author Member Share Posted September 6, 2017 No I haven't, so you're suggesting I export the scene I want to import, then import the OBJ as a 3bfile? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 6, 2017 Share Posted September 6, 2017 Try this please 1. File > Save 2. Create a new Layer in VoxTree 3. RMB over the Layer and use: Import 3B File Quote Link to comment Share on other sites More sharing options...
Member Nidhogg Posted September 6, 2017 Author Member Share Posted September 6, 2017 Apologies, I didn't explain myself well enough. This is the process I'm already trying. I right click, Import 3b File and pick the file I want. What happens next is that most of the model I already had in the scene disappears. I think it may have to do with instancing, since all the instanced Vox Layers and their source disappear, however they stay within the Vox Tree. Im trying to create a workflow involving kit bashing different files together to generate complex ship designs which maintain the instances and shaders as to reduce time and processor speed. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 7, 2017 Share Posted September 7, 2017 Are you creating a new layer before to import into it ? Quote Link to comment Share on other sites More sharing options...
Member Nidhogg Posted September 7, 2017 Author Member Share Posted September 7, 2017 Yes, fresh layer belonging to the Root. Quote Link to comment Share on other sites More sharing options...
Member Nidhogg Posted September 16, 2017 Author Member Share Posted September 16, 2017 bump Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 16, 2017 Share Posted September 16, 2017 How can i help ? using latest version 4.7.37 i tested this workflow: - Create an object. - Clone Instance. - Save project. - Add new layer and create new object - Clone Instance - RMB and select Import 3B file - All object and instances are loaded in the scene and works fine Quote Link to comment Share on other sites More sharing options...
