Member JustAnotherName Posted September 12, 2017 Member Report Share Posted September 12, 2017 (edited) Hey guys, I was trying to get a catsuit pattern in Marvelous Designer since it has flattening capabilities. Problem is, you apparently cannot draw seam lines on bare skin as I need to do. It would be a massive advantage to do it in MD, since you only need body measurements which can be edited on the model (no complete 3d scan necessary). Can you give me a simple procedure to draw a similar avatar in 3dcoat with defined measurements as in the attached picture? Please mind that I have nearly non existant drawing skills. Just used 3dCoat and Retopo Room for pattern creation before. Edited September 12, 2017 by JustAnotherName Quote Link to comment Share on other sites More sharing options...
Member JustAnotherName Posted September 15, 2017 Author Member Report Share Posted September 15, 2017 (edited) I am trying the model from makehuman.org out now but have measurement issues (they just have too less input fields for hard numbers) and the export of the UV map has the wrong scaling, still don't know why, it's always a factor of ten, but the lengths in 3dcoat are all correct. Edited September 15, 2017 by JustAnotherName Quote Link to comment Share on other sites More sharing options...
