Colour information missing when using smart materials
TC Oz
Hello everybody,
I have created a model in 3D Coat consisting of 3 objects with three different UV maps in it. Whenever I try to apply a smart material, only roughness, metalness and depth information is projected on the model. The colour information is missing no matter if I use the preview window or apply the texture. The colour information in the menue is activated. I am using 3D Coat version 4.7.36. Do you have an idea where the problem is?
Regards,
Ozan
Hi
Color, Specular and Normal map channels are check ?
Main colors selector is block ? -press over with RMB to blockin/out-
Is there any layer blending at top ?
The channels are checked. The color selector is not blocked. I have got a whole bunch of layers in the layers panel. Each objects has it's own diffuse, roughness and metalness layer. If I click those, the colour information is there but I want to have the combined information on layer 1.
Use the command Delete All Unused Layers to delete it.
Try adding a new layer on top and hand paint something, is working ?
Another interesting thing: The areas which are hidden from light are black. I have a black uv map and I have a black color, when I paint. I think it has something to do with the ambient occlusion. How can I fix that?
Edited by TC Oz
Latest version have great improvement on textures quality, give it a try.
Bake Ambient Occlusion again using this command and this parameter, i always avoid to use AO option when bake from retopo Room.
Calculate Occlusion in Paint room make better maps.
Hope this help.
O.k., thank you. I can paint the whole object now but even though I have installed the latest version, the fill bucket still gives another result than if I directly paint by hand. Is that a bug? And I have another question. Sometimes I have the feeling that in some materials the bump ist to strong. Even if I go down to 2% depth information, the bump ist very visible. Is there a way how I can "finetune" the bump information?
Edited by TC Oz
Create a new Project pressing Shift + M > Switch to Paint UV Mapped... option selecting any default models..
Use fill tool.
Can fill the whole object ?
It works with the default models. The preview windows shows almost the same result like the filled voxelobject. I mean the fill bucket works but there is a huge difference between handpainting  and filling when I use uv mapped objects.
It is possible that your voxel/surface mode object is hiding the baked normal map model.
If this is the case under the View window deselect "show voxels in paint room"
I have been able to achieve much higher quality by using a combination of high resolution textures and a nice high resolution mesh/UV.
Hello Carlosan and thanks for your support again. I am not quite sure if "show voxels in paint room" is the same as "Voxelebenen anzeigen" in the german version. Translated into english it means "show voxel layers". I couldn't find somethin meaning the same as "show voxels in paint room". I have attached a screen shot. I have deselected it but I still have the same problem using the fill tool (see pictures). The preview windows shows somethin totally different than the result of the fill bucket.
Can you share the model ?
Which workflow are you using ? Metalness and Specular are two different ways of working.
Do you apply UV-set and bake before switch back to Paint Room ?
