Unique Rock Sculpting Techniques in 3D-Coat
Carlosan
http://lesterbanks.com/2017/09/unique-rock-sculpting-techniques-3d-coat/
Anton Tenitsky Demonstrates His Rock Sculpting Techniques that is Unique to 3D-Coat
Anton Tenitsky goes over his way of rock sculpting in 3D-Coat that is a departure from what is normally seen with rock sculpting tutorials in 3DC. Creating rocks is a topic that Tenitsky has covered before, only using Zbrush as the tool of choice.
Since then, he has reconsidered the rock-making process, noting that 3DC has some advantages in workflow over Zbrush. “I’d say that in 3D-Coat, it is much, much easier” Tenitsky says. “The only advantage that Zbrush has is its noise modifier”.
Tenitsky has put together a Rugged Rocks Pack that is available for purchase. You can use the pack’s 17 high-quality rocks in your own work, or as a starting point for new work. Anton is mentor at the CG Spectrum College of Digital Art & Animation.
And I made a mistake about noise modifier!  You have it and it's pretty good. Like Zbrush's got more sophisticated one but it's more complicated while 3D Coat's is really good and it gives real feedback unlike ZBrush which shows you a preview that doesn't look same when applied.
Carlosan, I've added it to the description and I'll do a short video on it, maybe 5 minutes. It's not possible to reupload the video on Youtube, unfortunately.
druh0o, saving presets would have been cool indeed. Also having a noise brush would have been pretty cool. Right now I need to mask out everything but the noise area which is a bit time consuming.
