Member vertigo262 Posted October 12, 2017 Member Report Share Posted October 12, 2017 Hi, Is there a way to save the brush shape .spline, then use it for the curves .curve? For example, lets say I make a spline and modify some geometry, then I want to use the same path in the curves. But they are different save and load formats? can this be done another way, or the spline and curves used togethor? Or is there a workaround? This way you don't need to redo the splines and curves when switching between sculpting to curves Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 12, 2017 Reputable Contributor Report Share Posted October 12, 2017 There is no correlation between the two, but it would be nice if there were. Feel free to send the request to support@3dcoat.com. I was trying to get Andrew to convert the CURVES tool to using a variant of the E-Panel Splines, but he never responded. I hope the V5 cycle focuses heavily on the Sculpt Room, starting with Sculpt Layers, then revamping the Pose tool and Curves tool...and consolidating the brushes into brush/tool groups + folders for PRESETS panel. Quote Link to comment Share on other sites More sharing options...
Member vertigo262 Posted October 13, 2017 Author Member Report Share Posted October 13, 2017 Thanx...!! helpful but not helpful Would be nice if 5 supported realtime GI in the Sculpt room as well. So that their is less rendering to see what it looks like. Is there anywhere that lists what will be in Ver 5 on this site? Quote Link to comment Share on other sites More sharing options...
