Member locvio Posted October 14, 2017 Member Share Posted October 14, 2017 Getting laggy performance, even with basic brush. What are common performance tweaks? 1) Can I change where 3d coat is caching? Can hear it writing to HDD with every stroke.. would like to switch that to my SSD.. 2) Included specs below. .32GB RAM, Quadro k4000, I7 6core. these should be ok, it seems. Am considering upgrading to 1080ti though. Could that help? thanks! Alex 3dCoat in OGL mode. OS: Windows 10. Motherboard: ASUS P9X79 WS Processors: Intel Extreme Edition Core i7 3970X 3.5GHz/4.0GHz Turbo Hex-Core (15MB L3 Cache) NVIDIA Quadro K4000 Memory: 32GB Corsair Vengeance DDR3 1600Mhz (4x8GB) Hard Drive One: 120GB Intel 520 Series Hard Drive Two: 1TB Western Digital Caviar Black SATA 6.0Gb/s, 7200RPM, 64MB Cache Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 14, 2017 Share Posted October 14, 2017 Hi, Yes, a similar problem was reported before. Please contact support@3dcoat.com to ask about this issue. Thank You. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 14, 2017 Reputable Contributor Share Posted October 14, 2017 It doesn't do that on my end, so it sounds like there may be something going on with your "Documents/3D Coat 4.8" directory. Quote Link to comment Share on other sites More sharing options...
Solution Andrew Shpagin Posted October 15, 2017 Solution Share Posted October 15, 2017 After each stroke Coat writes Undo to disk. But usually you will never feel it. You may change path used for all files that are created dynamically (settings, new items, materials etc). It may take 500MB - 2 GB in general. Create file coat_data_path.txt in installation folder and put path to new placement of data, like c:\3D-CoatDataFiles\ Quote Link to comment Share on other sites More sharing options...
Member locvio Posted October 15, 2017 Author Member Share Posted October 15, 2017 thanks Andrew, tried some stuff. I will send my question to support, and report back here if there are useful findings.. Alex 1 Quote Link to comment Share on other sites More sharing options...
Member locvio Posted October 18, 2017 Author Member Share Posted October 18, 2017 After some feedback from Andrew, found that For me turning OFF Geometry-> Use CUDA checkbox made things much faster. Not sure why that would be with NVIDIA K4000, might ask them. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 18, 2017 Share Posted October 18, 2017 Have you tried using GL version ? It could improve your performance. Quote Link to comment Share on other sites More sharing options...
Member locvio Posted October 18, 2017 Author Member Share Posted October 18, 2017 thanks, I am on GL64.. again without CUDA performance seems much better. did send question about it to Nvidia.. 1 Quote Link to comment Share on other sites More sharing options...
