sun_smasher
[Solved] Square of UV set is too big
I'm getting this issue "The square of the UV set is too big." I don't know what could be causing this error. I've imported other models exactly this way before with no issue, but there seems to be an issue now? I attached my unwrap in the images. The poly count is 3,824 tris. If anyone has any ideas please let me know.
I had similar problem when exporting low poly (approx 350 polys) from 3Ds Max. What I did is, that I opened 3Ds max Unwrap UVW modifier on the model and problem was that UV in 3Ds max was in extremely scaled far out of the UV box. So I just scaled it down inside the box and exported, no error message then.
I am still not sure what adjustment needs to be done in 3Ds max to prevent this.
Edited by Skye
