Metin Seven
[Solved] Send retopo mesh to Sculpt room ?
Hi,
I was wondering if the following workflow is possible:
1: Sculpt a model using voxels and/or surface tools.
2: Use Autopo to give a nice quad topology to the mesh.
3: From the Retopo room, send the retopo object back to the Sculpt room, so you can sculpt on the retopologized mesh.
I guess a workaround is to export the retopo mesh and import it into the Sculpt room, but I hope that isn't necessary.
Thanks,
Metin
Hi,
You can do it easily using this command
hey,
from that point, would there be a direct way back to the retopo room ?
lets say in case you find some polygons you like to cut and delete etc..
how is that supposed to be approached ?
thanks!
You can adding an external script done by @ajz to
C:\Users\username\Documents\3D-CoatV48\Scripts\ExtraMenuItems
ExtraMenuItems.zip
