3D Coat Forums
Metin Seven
Some tools not corresponding to brush size
Hi,
I encountered some odd behaviour when using the Muscle, Snake and Spikes tools in voxel mode — they all show a much thinner result than the brush size. See the attached screenshots.
I'm using the Constant Pressure stroke type, so it shouldn't be a Wacom pen pressure matter. I've also tried to increase the brush depth, to no result.
The odd thing is that only the Toothpaste tool does correspond to the brush size, as you can see in the first screenshot.
Did I perhaps activate some option? Because until this session the tools did correspond to the brush size.
I'm using 3D Coat 4.8.03 for Mac OS.
Thanks,
Metin
Edited by Metin Seven
Additional info
Trying resenting Tapering to default.
Thanks, @Carlosan. Strangely, today everything works as expected again, without having changed anything. While yesterday even quitting and restarting 3D Coat didn't have an effect.
Maybe strange things start occurring when Mac OS has been running all day without restarting, causing RAM fragmentation / input oddities / aberrant GPU behavior.
But I'll keep your suggestion in mind in case the issue returns, thanks.
