New Member photonmammoth Posted November 17, 2017 New Member Share Posted November 17, 2017 Hey guys! So I just picked up the trial for 3Dcoat today after watching most of the videos, and I imported a model I have from zbrush (that is a little bit off of 0,0,0 but I figured no biggie cause local symmetry) but when that is enabled in the symmetry window in the retopo room, nothing seems to happen at all?? I've read through this post on the issue and there doesn't seem to be much of a fix? Also how does the bounding box selection for symmetry work exactly? Couldn't find any explanations on that but it sounds like it would be helpful Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21650-local-symmetry-non-existent/ Share on other sites More sharing options...
Carlosan Posted November 17, 2017 Share Posted November 17, 2017 Hi Can you attach your settings at import. You can change on the import tool the center. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21650-local-symmetry-non-existent/#findComment-149338 Share on other sites More sharing options...
