wlokaz
Baking flat surfaces gives relief surfaces (cushions)
My name is Vladimir, I live in Poland. I'm a 3D graphics enthusiast. Of course, 3D Coat, as well as Vue.
Please help. I am preparing a model with flat surfaces in "SCULTP" and doing a retopo model. However, after baking the model for painting the flat surfaces become convex, are not quite flat (cushions). Depth of paint set to "0". I enclose examples. What is the hint of what to do to paint a baked surface on two sides?
Regards  (google translate :-)
Hi
After baking the model for painting the flat surfaces become convex.
Try before baking change Sculpt shader to flat.
RMB over the shader > Edit permanent... > Switch Flat Shading ON
Hi
Po upieczeniu modelu do malowania powierzchnie płaskie stają się wypukłe.
Próbuj przed wymianą piekarnika Shader Sculpt na płaski.
RMB nad cieniownikiem > Edytuj na stałe.... > Włącz włączanie cieniowania płaskiego.
You can also hide normal map layer in paint room to paint it over again a new depth map.
Można również ukryć zwykłą warstwę mapy w pomieszczeniu malarskim, aby ją ponownie pomalować.
To paint a baked surface on two sides use the stroke command Ignore back faces off, and BackfaceCulling = off
Aby pomalować wypaloną powierzchnię z dwóch stron użyj polecenia Ignoruj tylne strony, a BackfaceCulling = off.
Remember to switch off Show voxels in paint room too
Pamiętaj, aby wyłączyć Show voxels również w malarni.
Thank you for the tips on getting flat surfaces. In doing so, I found a solution.
This involves improving the retopo grid. I had to line up already on the plane close to the existing retopo lines on the curvature. This caused the surface to not seem to swell up like a pillow, but the new line is already flat:boast:.
Best wishes  :D
