[Solved] Pose tool no longer colorful
Forikundo
Go to solution Solved by Shift Studio,
Hi guys, I know probably this is a easy thing but cant figure out how to fix it.
In voxel mode when i change materials to use someone more confortable for sculpting the pose tool has no longer the colorfull gradient but a grey one. Its harder like this to see how its working.
Not Sure what version of 3DC you are using but here is a sculpting shader that shows the red pose colors. I created it from another default shader.
It uses what is called " Sculpting light". That is a form is shadowed on each side with the brighter part in the center. It revels form this way.
It is created as a extension. Install from the file menu--- Install extension. restart 3DC and it will be in your shader list.
I use Beta version 4.8.07 but should work in the last several versions and the one you download from the main 3DC website.
Sculpting Shader.3dcpack
Edited by digman
More info
  • 6 months later...
On 12/9/2017 at 11:46 AM, Forikundo said:
Thank u so much, im going to try this right now.
Im using 4.8.03 so I guess it should work
I'm having the same issue you're describing in the first post.
Changing the shader seems like a strange solution. Did it work for you?
Thanks, Shift Studio.
  • Solution
Hi Carlosan,
I'm using v4.8.14.
I tried using a different shader in the sculpt workspace and that worked! I'm surprised, but as I think about it I guess it sort of makes sense.
The shader I was using was 'Skin' in the Misc. folder.
