retoporoom - how to use symmetry to recognize and fix other side of retopoed mesh via brush function and keep UV intact?
myclay
Hi all,
what needs to be set again, to make 3DCoat recognize the other side of a fully retopoed mesh for symmetrical brushing over both areas?
In Topogun it was quite simple, load up your fully retopoed mesh, activate "symmetry"and then start brushing for relaxing the mesh.
Retopo room---Retopo Menu---deselect virtual mirror mode if selected.
Press "S" on the keyboard to bring up the symmetry panel.  Select  Enable Symmetry and the axis you need.
