Surface material/UV Set problems when exporting from coat
MysticTeacup
Hi guys!
I'm having problems exporting from 3D Coat to Sketchfab. When exporting to Sketchfab all of my UV sets are being separated into Surface Materials, so it's making my life super complicated when trying to assign textures in Sketchfab. Is there any way I can group Surface Materials? I have 10 UV sets, which is turning into like 20 odd surface materials... Pleaseeeee help!!
Thank you :)
You can try to UnifyUVs
This tool merge all your UVsets into one
remember to use the command Delete unused UVs after that.
Or export UVsets as tiled
