Member kwhali Posted December 20, 2017 Member Report Share Posted December 20, 2017 When running the Geometry menu and choosing close holes, the popup is aware of 50+ holes. I ask it to close them, some tiny holes that were not easy to spot such as single triangle become large, however, hole fill appears to have failed. Can I some how highlight the holes instead or cycle through them with camera aligning to the hole with previous and next buttons to navigate? As it is surface, the mesh have some areas that might be considered a hole but is not, eg window or door cavity with no thickness . Perhaps this causes the failure. I could manually repair actual holes if coat could show me where they are. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted December 20, 2017 Reputable Contributor Report Share Posted December 20, 2017 (edited) Yesterday I posted about this subject in the Beta forums. Feel free to add your own comments. A validation checking routine of the mesh and marking of the error areas like Mudbox would be very helpful to the end user. A must for Autopo to function correctly. Edited December 20, 2017 by digman 1 Quote Link to comment Share on other sites More sharing options...
