Member Eymerich Posted January 5, 2018 Member Share Posted January 5, 2018 (edited) I tried to make uv of the following object in 3dcoat when i press the "apply the uv set " The triangle on top in someway is missing and shows the "effects " in ao if i try to texture these are results: Missing the plaster definition in same area. The model is in blender and exported in 3dcoat. Appreciate any help Edited January 5, 2018 by Eymerich Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21859-uv-problems-ii/ Share on other sites More sharing options...
