Member GIS3000 Posted January 10, 2018 Member Report Share Posted January 10, 2018 Exported color map looks different from viewport. My highlights are missing. what's going on? Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 10, 2018 Advanced Member Report Share Posted January 10, 2018 (edited) how did you make the highlights ? With specular ? Then this should be in the specular map (or rough, metallness) and not in diffuse map. If you export, you can export the other maps too. Edited January 10, 2018 by houGenie Quote Link to comment Share on other sites More sharing options...
Member GIS3000 Posted January 10, 2018 Author Member Report Share Posted January 10, 2018 Well, the view port image is the flat color mode. the highlights are made with a grey scale curvature map and overlayed. BTW, is there a way to change the work environment into Diffuse, spec and normal mode? I can't seem to get rid of metalness. Even thou I selected Gloss/color specular in the export/import work flow. thanks Quote Link to comment Share on other sites More sharing options...
