Advanced Member houGenie Posted January 11, 2018 Advanced Member Report Share Posted January 11, 2018 (edited) Hi guys, I have a cut off issue in voxel room. I try to cut with depth but independent of the depth setting the cut is always the same. Additionally when symmetry is on, the depth setting is ignored completely and it cuts through the whole mesh. I am using orthographic view and when cutting I am looking in the normal direction (screen based cut). Any suggestions to resolve this issue ? Using version 4.8.09. Thanks in advance. Edited January 11, 2018 by houGenie Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 11, 2018 Author Advanced Member Report Share Posted January 11, 2018 Okay with ignore backfaces option it works better, but seems that it does not work correctly the most of the time either. Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 12, 2018 Author Advanced Member Report Share Posted January 12, 2018 Seems the same with split tool. Anyone having these issues too ? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12, 2018 Report Share Posted January 12, 2018 Are you changing Depth Limit parameters ? I see that is switched ON. Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 12, 2018 Author Advanced Member Report Share Posted January 12, 2018 3 hours ago, Carlosan said: Are you changing Depth Limit parameters ? I see that is switched ON. Yes it is switched on because i want a cut with a specific depth. But sometimes the change of the paramer does not change the depth at all. Or you enter a very small value, and the cut is really deep, and so on. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12, 2018 Report Share Posted January 12, 2018 May be your model is very small ? Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 12, 2018 Author Advanced Member Report Share Posted January 12, 2018 (edited) 1 hour ago, Carlosan said: May be your model is very small ? Scene scale is on 1 and the model is around 1m. Don't think so. Edited January 12, 2018 by houGenie Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12, 2018 Report Share Posted January 12, 2018 What about same workflow with new fresh project loading any default model ? Quote Link to comment Share on other sites More sharing options...
Advanced Member houGenie Posted January 12, 2018 Author Advanced Member Report Share Posted January 12, 2018 Ok I think I have the solution. The depth is calculated from last pick point. If you keep this in mind, I think it works correct. Will test it more. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 12, 2018 Report Share Posted January 12, 2018 The depth is calculated from last pick point. Yes. Quote Link to comment Share on other sites More sharing options...
