New Member Baelein Posted January 15, 2018 New Member Share Posted January 15, 2018 Hello, I'm relatively new to 3d coat but my youtube research hadn't found a solution. In my workflow, I'll generally create and sometimes uv a mesh in maya and bring it into a program like 3d coat or substance painter for texturing. The 3d coat habit I've picked up has me separate different components from the mesh during the modeling process so I can use the 3d coat fill tool to just paint that component instead of the whole object. My question is, can I take that another step further and get 3d coat to see those separate components as different paint objects so I can hide them if I need to paint behind them? Thank you. Quote Link to comment Share on other sites More sharing options...
Advanced Member Findus Posted January 15, 2018 Advanced Member Share Posted January 15, 2018 You can hide elements and uv islands in the uv room, the paint room will be updated accordingly. Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted January 15, 2018 Advanced Member Share Posted January 15, 2018 In Maya just give the model different Material to the parts you want isolated (name them as to help you in 3dc Mat_wing) . they should come up in the Paint Room with Surface Material > then just turn them on /off. Or use paint bucket tool that will also have surface mat. Hope it is what your asking about. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution houGenie Posted January 15, 2018 Advanced Member Solution Share Posted January 15, 2018 This post was recognized by Carlosan! houGenie was awarded the badge 'Helpful' and 1 points. When you have different parts in maya (multiple mesh parts) then they are seperated in 3d coat when you use obj format. in the voxtree or retopo objects you can than hide the individual parts. Quote Link to comment Share on other sites More sharing options...
