Member Missy Posted January 18, 2018 Member Report Share Posted January 18, 2018 I was playing around with the different Splines for the Curve Tool. Now I can't seem to disable it. I want to use the Snake Tool without Splines but I keep getting the Spline. There doesn't seem to be a "Disable" button for those. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted January 19, 2018 Reputable Contributor Report Share Posted January 19, 2018 7 hours ago, Missy said: I was playing around with the different Splines for the Curve Tool. Now I can't seem to disable it. I want to use the Snake Tool without Splines but I keep getting the Spline. There doesn't seem to be a "Disable" button for those. Did you select the SNAKE tool? If so, can you hit ALT + SHIFT + S and share the screengrab, here? Quote Link to comment Share on other sites More sharing options...
Member Missy Posted January 19, 2018 Author Member Report Share Posted January 19, 2018 Thank you AbnRanger, but when I opened the program today and tried the Snake tool everything was fine. Yesterday I tried and tried, but the Snake tool kept giving me a snake with one of the built in Splines for Curves config. Like instead of a clean snake, it would give me the "Spring" spline. I could go in and change the spline but didn't know how to disable it altogether. If you look at the "Stencils" menu, there is a box you can pick to "Close" it and disable that function. I don't see that option for the Curves Splines menu. I'm afraid to try to duplicate the issue I had yesterday in case I get stuck with the splines again if I want to use the Snake tool. But here is a shot of the Stencils menu with the "Close" option I'm talking about. It would be nice to have that same option in the Curves Splines menu. Thanks Quote Link to comment Share on other sites More sharing options...
