heartnotes 0 Report post Posted February 3, 2018 So the line along the bottom tells you how many Ngons, but is there a way to flag where those Ngons are? (Ngons are polygons with more than 4 sides) Share this post Link to post Share on other sites
Fluffy 19 Report post Posted February 3, 2018 Selecting all the faces of your model then using the Retopo menu > Select Faces Picking Method > Select N-Gons command will leave only the Ngons selected. 2 Share this post Link to post Share on other sites
Tony Nemo 393 Report post Posted February 3, 2018 You can even avoid selecting all the faces as the "Select Ngons" command will do it for you. Share this post Link to post Share on other sites
heartnotes 0 Report post Posted February 3, 2018 Works perfectly, thanks! Share this post Link to post Share on other sites
