Member Ruud Posted February 21, 2018 Member Report Share Posted February 21, 2018 Hello everyone, Maybe a stupid question but i'm experimenting a lot with the different sculpting tools and i was playing around with the stylus settings (depth, radius, opacity). Does the opacity actually work within the sculpt room or is just for the paint room? Thanks! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 21, 2018 Reputable Contributor Report Share Posted February 21, 2018 The only effect opacity has in the sculpt room is in Surface mode when you switch to the paint room for vertex painting. Another name it goes by is Poly painting, no Uvs needed. You will need a high polygon model to get quality painting because it is based on the amount of vertices you have and is not pixel based. Quote Link to comment Share on other sites More sharing options...
Member Ruud Posted February 21, 2018 Author Member Report Share Posted February 21, 2018 Roger, thanks! Quote Link to comment Share on other sites More sharing options...
