Member Exsulator Posted February 28, 2018 Member Share Posted February 28, 2018 (edited) To bake parts of my retopo separately, I need to select them and bake while the option "bake selected only" is checked. Naturally I select a rectangular lasso for this. Then I start baking. That`s when 3D Coat awkwardly insists on keeping the rectangular select tool instead of letting me use my cursor to adjust scan depth. If I could only use the a regular stroke mode, I could paint as usual. So basically, you need to abort the whole baking process, switch stroke mode, then re-enter. Edited February 28, 2018 by Exsulator Missing tags Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 28, 2018 Reputable Contributor Share Posted February 28, 2018 (edited) Good request The focused window would not override the ablity to change the brush. There are other ways to select your retopo object layers for your FYI. Shown in the picture. "Select all faces on this layer" Select by Uv islands using a regular brush to select them. Not as efficient as the above. You must be under the UV section for this method to work. Select by clicking on a Retopo mesh face in the UI. It will select the UV island it is associated with. When a face is highlighted, then you click. Be a little careful not to select an edge as it will create a uv seam. Hold down the shift key to add to your selections of uv islands. My method though it is always an artist call. 1. First, I do my corrective projection cage work using the feature shown in the second picture. 2. Once done with the corrective projection cage tweaking, I select the retopo meshes by one of above mentioned methods. Then I run Bake ---- Bake w/ Normal Map (Per Pixel). Edited February 28, 2018 by digman 1 Quote Link to comment Share on other sites More sharing options...
