3D Coat Forums
fractionalist
NODES: Replace 'Mapping' with 'XYZ Sliders'
Replacing the MAPPING node with several 'XYZ Vector Slider' nodes - would be helpful - give more finite control if it were possible to configure the maximum-minimum values with an IMPUT data-value at each end of the slider.
See attachment:
Replace XYZ
You can get the XYZ values of the UV by using a "Separate XYZ" node:
But to adjust these nodes manually I guess you have to use a script node using an OSL script. I have no knowledge about writing OSL though. Maybe this can help you.
Another idea:
Create a Group with this setup (Create the node setup, select all and press Ctrl +G to group them:
You can drag t he Group Output nodes to the second input of each Math node.
Maybe playing around with the Math node can help you out here. The final group can be used like this:
WOW~! Gee! These ideas are GREAT... brilliant ideas! Thank you! I was just wondering how difficult it is to learn Python to write these... ha-ha!
Here's my current configuration:
Edited by fractionalist
adding Python Node Code
I believe this is the code for writing a slider node for 3dCoat - Python?
http://effbot.org/tkinterbook/scale.htm
The Tkinter Scale Widget
The Scale widget allows the user to select a numerical value by moving a “slider” knob along a scale. You can control the minimum and maximum values, as well as the resolution.
Hi. Tkinter is Python's standard GUI Library. It will not work in Blender since Blender has it's own GUI Framework called GHOST that's developed with OpenGL calls.
I did not look into Blender's Python API that deep but the only way to come up with a single slider node seems to be OSL scripting.
Maybe someone at the official Stack Exchange has another idea. :)
BTW.: What do you mean with "3DCoat Python"? AFAIK 3D Coat has AngelScript support (or even direct C++ API). Please correct me if I am wrong.
Edited by Haunted
I'd like to get code similar to this to add a NODE VECTOR SLIDER to 3dCoat - any ideas?
from Tkinter import *
master = Tk()
w = Scale(master, from_=0, to=100)
w.pack()
w = Scale(master, from_=0, to=200, orient=HORIZONTAL)
w.pack()
mainloop()
To query the widget, call the get method:
w.pack()
print w.get()
The default resolution is 1, which causes the widget to round all values to the nearest integer value. You can use the resolution option to specify another resolution; use -1 to disable rounding.
w = Scale(from_=0, to=100, resolution=0.1)
adding code content (link)
I'm in Mainland China - the Firewall here blocks the Java so I can't log into Stack Exchange... to post - perhaps someone else could see if there's a possibility to locate a vector slider - or the code?
ERROR MESSAGE
Blender Stack Exchange requires external JavaScript from another domain, which is blocked or failed to load.
http://www.outpostpm.org/scripts/index.html  or here OSL Script node: Slider with value range between 0 and 1 (like Fac) https://blender.stackexchange.com/questions/48821/osl-script-node-slider-with-value-range-between-0-and-1-like-fac are some hope for blender slider code...?
PS I wrote 3dCoat - meant Blender!
This may be the answer: https://blender.stackexchange.com/questions/40770/possible-to-control-a-driver-from-a-group-node-input-slider
Link to Blender Vector Slider Node Code
Hi,
did your try posting your question here: http://www.blenderartists.org/ ?
Except my solution with groups to control each X Y Z value separate I posted above, I can't help you with the OSL. Maybe someone at blenderartists forum can help you out to get the math done the way you want.
Check out this one:
https://blender.stackexchange.com/questions/58426/use-another-node-to-control-vector-mapping/58428
Edited by Haunted
Hi Haunted,
Thanks for the tip! Actually, being behind the GREAT CHINESE FIREWALL makes it difficult to get onto Stack, or anywhere outside the Great Wall... however, after awhile I managed to get a post on the group you suggested, thanks again.
Cheers,
Ced
Iyad,
You're a genius, very nice work!
Instead of having one MAPPING Node which contains the Vector Slide commands ALL-IN-ONE, I'd prefer to have (3) texture VECTOR-SLIDER NODES, insomuch, what I'm after a proprietary NODE SLIDER for each of the following actions:
  1. DOLLY
  2. PAN
  3. ROTATE
You designed & built FOUR separate proprietary VECTOR SLIDER nodes for the above functions?
Something like this (See Attachment)
Thank you - a miracle!
