New Member lollarpop Posted March 15, 2018 New Member Share Posted March 15, 2018 In Mudbox you can use the grab brush to move two fingers or legs when they are close together, because it is selecting based on surface instead of volume around the brush. Can 3D coat do this? Quote Link to comment Share on other sites More sharing options...
Advanced Member Falconius Posted March 15, 2018 Advanced Member Share Posted March 15, 2018 The move brush does something like the move brush in zbrush which I assume is the same, only 3d coat does it poorly. The pose tool however will suit the same needs. Use line select and start just below the joint where the limb meets the model and drag it down the limb, then shift move the gizmo around to where you want to change the object from and start using the gizmo controls to alter the model. 1 Quote Link to comment Share on other sites More sharing options...
