Advanced Member blackant Master Posted March 19, 2018 Advanced Member Report Share Posted March 19, 2018 Hello guys, it's not the first time i'm confronted to this kind of problematic, while painting mecanical parts over plane or space shuffle like actually, i would like to be abble to correct the orientation of the projection in a direction without changing the projection direction on the others sides... as you must see on the attached screenshot, the orientation of the material is going is the good direction. but not the sides but rotating the texture projection will not help in this situation because it will rotate bothe sides of the cube projection Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 7, 2022 Report Share Posted December 7, 2022 You need to rotate the UV island to keep same direction Quote Link to comment Share on other sites More sharing options...
