guats
Fill only 1 UV Island at a time in the 3D Viewport
Hey Gang,
Just wondering if anyone knows a way to fill only 1 UV island at a time in the 3D Viewport with freeze or just colour?
Would save me a lot of time instead of hunting down the island in the Texture Editor. The program got into a weird state the other day and was doing this, and I'm unsure if it just bugged out or I found it by accident.
Cheers :D
HI
Create a UV ID map; make a layer where each UV island is filled with its own random color. Then fill with freeze & paint tolerance the piece you want to work on in the viewport and invert. Clear the freeze to work on the next piece.
You welcome.
It certainly seems like a very complicated solution for something that is so easy to do in the UV and Retopo room. I hope we can develop a way to select Island in the paint room like those two.
I was thinking about... another way is to use Simply Polygon stroke.
Use it with View > wireframe and view seams (w and shift+w) enabled
This stroke mode allows you to draw masks quickly by selecting polygons.
