JPG Compression on Export
MaxHancock
The JPG compression level is pretty high when exporting from 3D-coat. The quality is pretty bad. Is there a way to set the compression level directly from the application?
I know that it is better to use TIFF or PNG for higher quality images with no compression, but JPG is a requirement, and I'd like to know if there is a way to set the compression level in 3D Coat itself so that I don't need to do fix it post-export.
