Kargall
Various questions about new tools and more
Hello,
I have some questions :
- Where can I find a tutorial on the Tube / Array tool?
Are there videos?
There is nothing in the manual about it.
- What is the difference between the Vox tool and the Coat tool?
Thanks, have a good day
Edited by Kargall
Hi!
It is still in beta state, so there is no good documentation. But generally tool built to be self - explanatory. Just enable Preferences->ShowNewCurves and play a bit. There is menu Curves that helps to start.
It is developed so that user don't need to read docs too much.
Andrew
I would advise just trying it. If you hover over the tool it will tell you all you need to know really. Aside from that if you just use it you'll see.
The Coat tool is an editable mesh after applying it. You can still edit points on the spline and it is updated in real time. The vox layer tool you can not edit after applying the mesh. That is the biggest difference.
FYI. You can add points, delete points, move points etc, etc.
OK thank . I just understood, my English and very bad, and the use of the tool was not correct.
:good:
[resolved]
Hi
This tool is in beta stage, and it is changing many times with the development. That is why there is still no detailed documentation of how it works. For now the learning is based on trial and error until the final version comes out.
