orbiting navigation issue
Bio
  • New Member
Hi,
Orbiting around picked point (Alt-Z) doesn't work for 2-3 days now. Yes, it centers the view on picked point but doesn't orbit around it.
 I'm relatively new to 3d coat and maybe I miss something, but i need that function badly! any suggestions will be appreciated!
  • New Member
1 hour ago, Bio said:
Hi,
Orbiting around picked point (Alt-Z) doesn't work for 2-3 days now...
I mean Shift-Z
Holding down the alt key and LMB on a spot on the mesh will orbit around that current pick point as long as Rotate around current pick point is selected under the camera menu.
Keep the alt key held down as you rotate the mesh or keep selecting new pick points to change as you rotate.
Shift---Z on my end works as zoom to current pick point. That is the default as I have not changed it.
Does this help you.
