3D Coat Forums
TLE
[Solved] Multi layers select cause problem.
it doesn't deselect the layers when using transform tool. and it cause problem when you try to move only one layer. try it out and see what i meant.
I confirm this problem.  When auto click is enabled, it should not add to your selection but only choose the layer you select. That is the standard in most programs
When holding down the shift key or the Ctrl key then you can multiple select layers which is also the standard in most programs.
Solved on version 4.8.16
