3D Coat Forums
4 hours ago, Andrew Shpagin said:
fixed scale of objects in Instant meshes
Scale is working correctly for instant meshes.
Retopo via decimation still only supports a scene scale of 1.00. Any other scene scale and the retopo mesh is too large or too small according to the scene scale set.
I posted about this a few days later after the instant meshes scale problem post. Just a reminder here if you did not see my post.
12 hours ago, Metin Seven said:
Looks good indeed, but has 3D-Coat's native auto-retopo been improved as well? I thought only the Instant Meshes algorithm was added.
Hi , sorry for the late reply , not sure , but i test it each time and i get similar results , this time i got significantly better results with the exact same settings.
I have put a lot of time in autopo research as i use it every single day for the last 3 maybe 4 years? Anyway , i made tons of assets with it and learned how to
work with it , small assets , big , parts , hard surface or sculpts , always  getting very precise results.
Again this time i think that something changed  either retopo or the default manikin model  as this is the first i test autopo with.
Are the beta files downloading slow for anyone else? Ever since v14 my download speeds to get the files take and hour+ where it used to take just 5 mins before.
Interesting, thanks @Michaelgdrs. I'll do some tests too.
Has anyone tested the curves?  I've played with it a little bit, but I don't know how it's intended to be used.
Andrew, is it possible to make patches out of curves?  Kind of like pseudo polygons?  I think it would provide a powerful framework for both sculpting and retopology.
The results I had were interesting.  But I think I encountered some bugs in 14C.
First bug -> I created a curve and I tried filling the curve with voxels and nothing happened.
Second bug -> Then, I tried making a curve and aligning a curve profiles along it, which worked, but it started creating a ton of new mirrored layers everytime I moved it to adjusted it.  So on one side of the symmetry plane, I had the curve with the curve profile on it, and on the other side of the symmetry plane, it stamped in a mirrored version of the curve profile on a new layer.  After adjusting my curve profile for a little while, I had hundreds of layers showing a mirrored version of all the tweaks and changes I made.
this is an issue that has been bugging me for a while and it's gotten to the point where it is happening all the time.  Usually after using the move tool or the scrape tool, the mesh produces all these square holes, effectively ruining your model.  You can't undo (the holes just re-arrange themselves), your only option is to load a save.  I am using version .14.  Here's a picture of the problem...not sure if there is any solution to this, but thought I would ask as this is very frustrating.
I started a New Curves beta thread so we can have a central thread to post about the new curves. They have matured enough to start this thread to give the development team some feedback.  Make sure you are using the lasted 3DC version when posting about bugs as they could be fixed in a newer beta.
1 hour ago, lesaint said:
I've never seen this, is this in surface mode or voxels ?
this is in voxel mode.
It happens randomly, so right now my solution is just saving all the time. =)
edit:  it also seems to happen using the vox hide tool.
Edited by nobackup
Try deleting the options xml file Under Users/ MyDocuments/3DCoatV48. 3DC will recreate xml file upon restarting. If not using windows then wherever the the 3DCoatV48 folder resides.
thanks - I will try that =)
On 5/4/2018 at 3:56 PM, Michaelgdrs said:
Marco , kindly re download , there is a new build available.
Hi Michael!
Solved! Thanks a lot!
I had to completely uninstall 3DCoat both  my laptop and desktop, then delete ALL folder related to 3DCoat in c:\Program Files.... and "Documents" and reinstall again the latest 4.8.15c build.
I hope not to have again this issue with next builds.
Marco (mkdm)
Beta version 4.8.15
Pose tool rotations.
Voxel mode and surface mode. Surface mode since it is polygons they get stretched.
This is still a  current problem in the pose tool. The outside of bends are stair cased or stretched depending upon which mode you are in. I tested many times and happens in all rotations when using the pose tool. Smaller rotations less, large rotations more.
If possible can the bend be recalculated and resampled. The whole bend as the effected voxels or polygons could be recalculated.
The pose tool is a powerful tool, this problem hinders the use of the Pose tool for rotations.
Thank you for your consideration and depends upon the development schedule for any improvements to this problem.
I used a very soft pose tool falloff.
Edited by digman
Added information.
AbnRanger mentioned bevel profiles in the Beta curves thread.  I will add my first thoughts here.
The ability to create user edge beveling of objects would be a big plus for sculpting esp hard surface. We have currently the ability to bevel some primitives when adding them to the sculpt room.
AbnRanger mentioned the use of bevel profiles or possible by angles of the edge.
The current fillet tool is a possible way too but for an already imported model.
Surface Mode.
One way to select specific edges could be by freezing. Freeze the edges you want to bevel. Invert the freeze and only the bevel would be applied to the unfrozen edges. Now the freeze would not have to be perfect but large enough to section off an edge / edges.
All the above depends upon what is possible in code and in development schedules.
Another user posted about the problem. So is it confirmed as it happens on my end too.
Beta version 4.8.15 installed. No XML error appears.
If you load a 3DC beta version lower than 4.814, you get this error shown in the picture.  You can press ok on the error message and 3DC still loads correctly.
I tested loading, 10, 11 and 13. All had the error message appear.
21 hours ago, Andrew Shpagin said:
I updated download link to fix problem of opening some 3B files (related to Sculpt->Curves tool).
The error problem of opening 3DC versions lower than 4.8.14 appears to be solved.
Beta Version 4.8.15C OpenGL. 64 bit Windows 7.
Possible random bug in using Undo. A few other users have reported this as well.
Voxel mode.
Pressing Ctrl / Z keys will cause 3DC to completely crash.  This is random but appears related to the included models and primitives.
I sent in the generated bug report.
I´m using 3D-Coat 4.8.15C(GL64)
___________________________________
I believe I'm having problems with brush move and some other brushes.
This error is happening to me in the Paint, Tweak, Sculpt room rooms (I have not tried the Retopo yet)!
I discovered that it also affected in the Cloth tool when I try to move the brush in the clothing simulation!
The problem is that when I start using the Move brush and other brushes, the cursor is shaking as if I was using Jitter Position in the Brush options.
I've checked all the settings and it still happens.
Probably a bug in the program ...
This strange behavior happens both when I use the mouse or when I use the tablet.
Please, I would like to know if this error is happening to you too ...
______________
Note: This bug is not happening with the DX version
______________
That sounds like your Wacom tablet needs to have it's driver updated. It's an input issue, so that would always be the first thing to check...drivers for your input device. I haven't noticed any jittering on my end.
The drive is upgraded from my tablet ... not the problem with the drive of my tablet as you can see on the screen captured that I took.
In the previous beta version, I did not have this problem and I'm also having no problem with the current version of 3D-Coat 4.8.15C (DX).
I'm just having the problem I quoted above with the current version of 3D-Coat 4.8.15 (GL).
I do not know what can be ... is it the video card update? (I find it hard to be because it works right on the other versions!).
I just tested with the old version 4.7.23 (GL) and everything is working properly.
I always use the DX version as it seems I notice some glitch in the GL version whenever I attempt to use (pretty rare)
Thanks for answering me ... I do not know what happened because I've always used the GL version and I've never had problems before.
I'll wait for the new beta to see if the same problem will happen! Until then I'll use the DX version as well.
I'm still using an old computer with 32GB of memory and NVidia Quadro 600 video card.
What would be the best version of 3D-Coat for my video card? DX or GL?
