When I import a mesh in the retopo room either via autopo or otherwise, the origin is moved to the center of the object, and changing it using transform doesn't work, it resets to the same origin point !
I guess I have to go back to 4.7 :(
--------- Edit :
Sorry, it appears I was mistaken.
It only appears to do so, The transform gizmo appears there in the center of the object, but in fact it exports with the correct origin.
And it is the same with 4.7.37C
Edited by lesaint
I made a mistake
17 hours ago, Carlosan said:
Try using this values please.
I dont understand why I'd have to go to the Retopo room to adjust scene scale.  I'm only uv mapping and painting then exporting. Sometimes not even painting - just uv map and export.
i tried this and my model disappeared in 3dcoat in the paint and UV rooms.
so my problem is  if I make an object in LW as 200mm wide, then save LWO, then import for uv map from main menu splash in 3dc, uv map, then export as fbx, then import asset in Unity it is 2mm wide
what is going on? Maybe I don't understand 3dc's rooms fundamentally, but I don't remember having a scale problem with the export before with this workflow in 3dc? but before there was not unity export preset in 3dc.  There is no scene scale in the export.
Thanks for explaining what I'm doing wrong  I think this has to do witn 4.8.03
I don't think it is related to Scale window. 3D-Coat imports and exports the same coordinates of object. But different software may interpret same values as meters/centimeters or millimeters. I on't know how is it managed in LW, but try to set different measure units in LW - meters, centimeters or millimeters and look how export differs in scale.
LW is meters and Unity doesn't specify a unit as far as I'm aware.  I don't know what 3dc default  unit is.
The reason I asked is that I did this workflow with 3dc several versions ago (4.x) and this scale difference didnt happen.  Any ideas?
By default, the units in Unity are meters.
I think 3d coat is mm since if you use the measure tool it starts as mm in default.  (Edit its meters as well)
Andrew is correct of course on what he says , now if there is a bug in something i am not in a position to know since in my workflow
Maya LT , Houdini , 3D Coat everything works fine.
Edited by Michaelgdrs
I have just tried to install 4.8, but my AVG flagged it as having a virus? I assumed It was possibly just part of it so made it an exception. When I tried to run it , it would not run and a box popped up saying It would not run because of virus. I uninstalled.
Any ideas?
Hmmmm , have Avira and it passed ok. There is no way of having a virus by the way.
Disable the antivirus , and install , it will work fine , then re enable the antivirus.
Thanks ,that sort of worked ...but during the process my GL icon shortcut got put in quarantine,now it is completey gone and I can only use the DX version...
question .How can I get my application  icon back...its nowhere to be seen,
Ive been using GL for everything for ages .Will using DX affect anything? ( I am using a GTX 1050 gfx card.)
thanks
Edited by stusutcliffe
I would prefer GL as well.
Try at the sandbox area of the antivirus or the quarantine area , not so familiar with AVG anymore.
I found it there ,but deleted it I think.... I thought I was maybe restoring it but I just deleted it...doh. So Its basically gone I think. I reinstalled everything but its still gone. Maybe I have to start from scratch, How would I do that ,Do I have to delete the users folders. This is all a bit beyond me. The Dx Version seems to work just fine, just dont like the thought that there is something missing that I broke.
edit , It just crashed  moving the color palette...sod it I will go back  to previous version...this really need to work at moment.
thanks for helping
Set scenes to meters before importing any of the assets into 3d coat helps ?
Will be great If I could add my input also, during import, some dimensions panel should display the physical size and global position of the imported mesh, and allow for resizing, scaling, rotating and adjusting, before the mesh is committed.
