Member GimbalLock Posted May 9, 2018 Member Report Share Posted May 9, 2018 Hi forum, I need to paint 3d strokes along the surface of a solid object, and then hide/delete the original so only the strokes exist as a hollow mesh with the overall shape of the original model. But I can't seem to find a way to put down clay in a seperate object and have it align to the surface of the first - is there a way? Quote Link to comment Share on other sites More sharing options...
Advanced Member Falconius Posted May 9, 2018 Advanced Member Report Share Posted May 9, 2018 Yeah. The copy tool would work for that sort of thing. This adds volume to both sides of the surface though so afterwards you might want to right click on the original layer and subtract from the new one (if you want to keep the original volume then duplicate it before hand). The other option is to use the vox layer tool and mask out the area you want extruded and it will put the extrusion on a new layer without affecting the original. 1 1 Quote Link to comment Share on other sites More sharing options...
Member GimbalLock Posted May 10, 2018 Author Member Report Share Posted May 10, 2018 Hi Falconius, Thank you for the help. When trying the first method, the copy tool wouldn't paint a stroke, but instead the original (ref) mesh would become selected - when brushing over it in a seperate layer as you demonstrate. I couldn't really make it work, I wonder why. Settings looked the same. The second method worked very well, and I ended up using that. It also had the benefit of supporting other alphas than round. Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
