Steam version impossible to update !
Hi i have teh steam version of 3dcoat, if i try to do an update called "3dbetatest444", the software do the update but DELETE the exe file so the program doesn't work anymore!!! And then i have to uninstall, disable the beta updates and reinstall this version 4.8.15D, how people do for using the 4.8.18 version ?
Edited by imothep85
This step is not working for you ?
On 2/15/2015 at 8:38 PM, fuzzzzzz said:
Steam can support Beta program, there is a tab under 3dcoat properties, many app use it to provide preview and beta program :)
Example
Open the steam client and go in Library. Right click on the app and select properties.
4 minutes ago, imothep85 said:
Please look at my screenshots above you can see how i updated the steam version, and like i said, the steam update for 3d coat kills the installed version !!!!
I've never used the Steam platform, but why would you use a version called "3dbetatest444"? Is that the only option available? Builds are not usually labeled that way. There should be a 4.8.18 build.
